Old 11-08-2004, 01:09 PM   #1
light bulb
I installed a new porch light cover and gasket. The old one was melted by heat. What bulb should I use as a replacement to prevent this from happening again. Once you enter the door, to the right, there is a light switch. Is this for the porch light?
Thanks for you help,
Bill
66 Tradewind is offline   Reply With Quote
Old 11-08-2004, 01:31 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
From what I understand, Airstream intended that light to be a "scare" light meant for only brief use. If you have the correct bulb in it, the lense will melt again. If you put a dimmer bulb in it, it will probably still melt in addition to putting out insufficient light.
In my Overlander, there is a switch above the door that supplies juice to one of the galley lights. Another switch, in a location similar to what you describe, operates the scare light.
Tom
Old 11-08-2004, 05:18 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I run a 18W bulb in my porch light, and it's been on for several days without schmelzing the lens. You can go down to a 10W bulb, with considerably less heat.
I am not sure about the functionality of this light, as mine shines sort of high up in the trees, and it is sort of directional, with a narrow beam ....what on earth were they thinking?
Uwe
www.area63productions.com
'Porch' Light Replacement Fixture with 1141 Bulb AirConditioner Electrical - Systems, Generators, Batteries & Solar 4 09-10-2015 11:56 PM
proper bulb for large door light? IPM General Motorhome Topics 3 03-19-2006 06:27 AM
Light Bulb Source Found TomW Electrical - Systems, Generators, Batteries & Solar 6 10-27-2004 03:34 AM
Closet light bulb Tarheel Electrical - Systems, Generators, Batteries & Solar 3 07-26-2004 02:04 PM
'64 Globetrotter Patio Light Problem sdresen Lights - Interior & Exterior 1 07-26-2004 10:27 AM
