Old 07-31-2016, 06:10 PM   #1
2016 30' Classic
Rocklin , California
Lifeline battery for 2016 classic
What model of lifeline battery do I need to replace the current current batteries in my 2016 Classic?
What 3 stage converter/ charger should I purchase that will fit and plug into existing system?
Gamehawkers is offline   Reply With Quote
Old 07-31-2016, 10:37 PM   #2
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
What batteries do you have now?
gandttimes is offline   Reply With Quote
Old 07-31-2016, 11:11 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Answers posted to this thread: http://www.airforums.com/forums/f37/...ml#post1829171
Old 08-01-2016, 12:11 AM   #4
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Why do you feel that you need Lifelines?
There are other choices out there such as Trojan or Crown. Just wondering why Lifelines?
Old 08-01-2016, 05:45 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Did the upgrade in 2007, SFSG.
Two Grp 27 100ah Lifelines and IOTA 55a DLS converter.
Lifelines made in USA to Mil/Spec....
IMO...well worth the investment.
Note.....strap added to lift battery over the sill on the Classic's battery compartment.....
ID:	268077   Click image for larger version
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-10-2016, 06:44 PM   #6
2016 30' Classic
From the research I have done. Lifeline batteries are top notch. I am sure others are good too.
Old 08-10-2016, 06:45 PM   #7
2016 30' Classic
The stock car batteries. I will use them until they fail then upgrade to lifelines
Old 08-17-2016, 02:02 AM   #8
2016 30' Classic
Stock Interstate truck batteries
Old 08-18-2016, 12:59 AM   #9
2016 30' Classic
I upgraded my charger/ converter to the four stage charger. I have to save up for the lifeline batteries. The 2016 classic has a battery box that maybe large enough for two 6 volts in series. I will have to do some research on that. It would be great if they will fit without any problems or modifications
Old 08-18-2016, 10:00 AM   #10
lewster's Avatar
The newer Airstreams can accommodate a pair of Lifeline GPL-4CT golf cart batteries with no modifications. They are 6VDC @ 220 amp/hours. The new battery boxes are a bit taller than the older models.
Lifeline batteries (Storage)? subfan1 Batteries, Univolts, Converters & Inverters 1 06-29-2010 09:18 PM
Lifeline Batteries? 2Tex4Fun Batteries, Univolts, Converters & Inverters 5 03-26-2009 06:04 AM
AGM Battery: Cabela's or Lifeline? Sheridan Batteries, Univolts, Converters & Inverters 11 03-06-2009 10:30 AM
Diehard Platinum vs Lifeline joe3957 Batteries, Univolts, Converters & Inverters 9 01-06-2008 07:05 PM
New Lifeline 6 Volt Batteries lewster Batteries, Univolts, Converters & Inverters 0 04-22-2007 06:24 PM
