Old 08-12-2005, 08:05 PM   #1
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
LED tail light conversion
Does anyone have a source for compatible LED tail light conversion for the square recent Classic tail lights.
I bought a set from Airstream at the International, then returned them when I decided to swap trailers. Sadly, my new trailer has incandescent taillights and I wish now I had kept the conversion kits.
Conversion requires 4 LED units which Airstream prices at $25 each. I suspect that the lights are available over the net for less than that if I knew where to look.
John W. Irwin
WBCCI #9632
Old 08-12-2005, 08:12 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
John, try www.led-r-us.com
That is where we got our clearance lights, they may be able to help you.
Old 08-12-2005, 08:21 PM   #3
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
IMOP, I think you'll be hard pressed to get led tailights for under 25 $ a piece. I have shopped around P-town and haven't found any yet for under 25 $. This is for my boat trailer, by the way. The Caravel is keeping its vintage wedding cake tailights.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 08-12-2005, 08:21 PM   #4
Pahaska's Avatar
Hays County , Texas
Thanks. I don't find the square light units there, but I'll email them and inquire.
John W. Irwin
WBCCI #9632
Old 08-12-2005, 08:24 PM   #5
Pahaska's Avatar
Hays County , Texas
This is just for the guts of the lights; no housing. Just a plastic box with 4 wires coming out of the rear. I suspect that $25 may not be a bad price, but what I had in my hands should be somewhat less.
John W. Irwin
WBCCI #9632
Old 08-13-2005, 04:38 AM   #6
Well Preserved
1993 21' Sovereign
John, I haven't had one of the newer taillight asssemblies apart. Does the light bulb point glass-upward, or glass outward (toward the plastic lens)?
If it points out, there may be another solution. Pick up a package of red LED 1157 replacement bulbs. They are $14/pair at many auto parts stores. The best part is, they push and twist into place just like the incandescent bulbs.
Old 08-13-2005, 05:31 AM   #7
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
Exclamation
Now these twist in kind, are they "just as good" as the true LEDs? or are they close to them,Car Quest has a kit for boat trailers,I put these in my 77 Caravanner and they look awesome,it took some customizing but when I mash the brakes, you can see them so much better ,
scf31 is offline   Reply With Quote
Old 08-13-2005, 09:12 AM   #8
Pahaska's Avatar
Hays County , Texas
I haven't looked inside the housings and my trailer i currently at the dealer waiting for a new refrigerator, so I can't easily check it.
By the way, I love the new teardrop-shaped marker lights. They are far more attractive and a lot brighter than the former lozenge-shaped marker lights. The trailer really sparkles during those early morning departures.
John W. Irwin
WBCCI #9632
Old 08-13-2005, 09:38 AM   #9
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
I saw this while browsing theu 'Schus News' on the WBCCI website:
August 2005:
"LED Taillights
2006 model Classic trailers come with LED taillights.
You can now upgrade your 1994 and newer Classic trailer taillights to LED.
The part number is 511973; four LED taillights are needed for a complete change out.
They are for stop, turn and taillight."
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 08-13-2005, 08:36 PM   #10
Well Preserved
1993 21' Sovereign
The twist in kind are in fact LED's. IIRC, there are 7 LED's arranged 6 in a circle around one center one. I put them in mine as a power-saving measure, but they wound up brighter, too. They burn less current, and they last longer. So, for no other reason than less maintenance and less strain on your tow vehicle's electrical system, they are worth a look, even if they are exactly the same brightness as the incandescent. I had taken some photos of the trailer with these lights in place, but I have since changed computers, and those photos seem to be among the missing from the move. Naturally.
Old 08-25-2005, 02:54 PM   #11
_
if you considering the led tail light conversion for the classics GO FOR IT!!!!
hi folks
while in jc last week for 3 days of warranty repairs (i'll post about this on the proper thread) i also asked them to do the led conversion.
best 100$ i ever spent......well 140$ with labor for install.
man these babies are bright!
i was still outside in the terra port going over my list of repairs when an 06 pulled in and started circling the pod. the instant he touched his brakes my questions about the leds were answered as the rear end of his trailer took on the look of an independence day light show!
whenever he'd release the brakes and shift to reverse, so that a comparison between the backup and brakes lights was possible, it was clear the led were 10 times brighter and better diffused that the standard rear bulbs. his wife commented that she could no longer stand behind the trailer to help with docking because the brake lights were "blinding".....of course we all know standing behind the trailer is a no no, so now she stands at the side which is safer anyway.
i wanted some of these puppies.
the conversion unit is a white plastic housing with the circuit board and leds attached. the entire unit replaces the old style by first removing the lens/cover (4 rusty screws) then removing the bulb housing (2-4 screws) and cutting the 3 wires. then the new unit is wired, fitted, screwed in and then the lens/covers are replaced.
2 units per side so the procedure is repeated 4 times.
most anyone could do this diy, but since i was in the holy land, i let the factory wise men do mine....i think they billed for 30 min labor.
i doubt these replacement leds are available yet anywhere but from the mother ship although dealers who stock big parts inventories could have them soon.
the unit (wiring, housing, circuit board, leds) are one complete unit the bulbs are not screwed or plug-in but rather part of the board. it looks like there are 10-16 leds on the board (i'll find my picture for another post) and they light up in different numbers/groups and patterns for running lights, turn signals, flashers and braking.
so if your running lights are on and you brake or turn the intensity and pattern changes BIG TIME.
another big plus is that these units use the original lens. the oiginal lens are designed to diffuse/scatter the light from one bulb. they are rippled on the back side and multi faceted. most led units have a lens that's smooth on both sides so the leds become very directional.....only bright when the viewer is in the optimal position (like the safari and retro housings)......anyway because this conversion uses the old style classic lens, the led light scatters and is very visible from all angles. also the entire lens cover seems to light up in a star&circle pattern that is very effective and distictive.
these puppies are cool.
the first few pics below were taken at high noon on a bright day with lights on flasher mode, which is similar to the brake light mode. even from the sides they are very visible. the last few pics are with the sun shinning toward the rear of the trailer, running lights on so they are on the least bright setting....you can barely see the clearance lights and side/running lights for comparison.
i was planning to ad a 3rd (brake) light but am very satisfied with this conversion.
i'll post pics of the housing and night shots.....when i find that memory card.
cheers
2air'
Name:	airstream led taillights 008.jpg
ID:	14229   Click image for larger version
Name:	airstream led taillights 009.jpg
Old 08-25-2005, 05:53 PM   #12
Well Preserved
1993 21' Sovereign
Now all we have to do is find comparable LED clearance lights for the bullet style lights such as are on the newer trailers.
Old 08-26-2005, 07:13 AM   #13
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
A/S Classic LED units
The new LED Classic taillights are not the low count LED modules that have been available for a couple of years in the Bargman housing. These units contain 33 ultrabright, wide pattern diffusion LEDs in each lamp mounted on PC board in a pattern that illuminates the entire lamp lens. All LEDs operate in taillight mode and then switch to an almost blinding level for brake light mode. I investigated the startburst modules about a year ago and decided to wait for a unit that contained more LEDs.
While the starburst pattern is nice, I much prefer the solid, intense, look of the new A/S units. The only thing I have noticed is the lens that ships with the new LED units is just a tad lighter in saturation than the original Bargman. The good news is that you can put the Bargman lens on the new units as they are mechanically and optically identical. Given that these are 33 LED units, the $25 price tag is actually a bargain.
David Tidmore
GM Roger Williams Airstream
Weatherford, TX
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 08-26-2005, 12:31 PM   #14
_
thanks david for the expert opinion
hi david and others
i knew there were a lot of leds on the board.....but couldn't decide which of those little lumps was/wasn't.....i was just guessing at 16 and >30 is really what i saw on the board (i post a pic of the unit).
but one thing i am sure of is these babies is bright! and i do like that.
really much brighter AND better diffused (which matters as much/if not more) that any other leds i've seen.
and you clarified my point that using the original lens is better because the faceted backs better scatter the led light.....a problem with most led kits.
best upgrade for the bucks to my '05.
cheers
2air'
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 12:52 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 08:52 AM
