Old 12-12-2005, 01:18 PM   #85
1992 34' Limited
Falls Church , Virginia
Photos??
Jim -
Trying to follow what you were saying about 'turning the LED bulb' but "not getting it" Photos? Same with the duct tape holding something... Sorry, I am the visual type and get lost in the verbage sometimes.
Glen, do you happen to have photos of the running light replacements you have done? See above - just a visual guy....
Thanks guys!
Axel
SilverToy is offline   Reply With Quote
Old 12-12-2005, 01:27 PM   #86
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
The bulbs are double contact and only fit in one way. Unfortunately the socket in the reflector is set so that the bulbs face the back of the reflector. Rather than try to turn the socket 180 degrees, (which I tried and they are built very well and can't be turned without damage), I bought new sockets from an auto store and inserted the base into the original sockets but turned 180 degrees.
I will try to get some pictures.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 12-12-2005, 03:22 PM   #87
The Hawk's Lair
cooperhawk's Avatar
Okay, I went out to the barn with the camera. Here are the pictures. They don't really show the light as they appear. It is dark in the barn and the flash made the led's look yellow in the picture. They are not. In the photos, both tail lights are on. One is the brake and the other without the brake. Also there is a picture of the reflector with the bulb in backwards.
ID:	17023   Click image for larger version
AKA THE GUNNER
VFW, LEGION, NRA
Old 12-12-2005, 03:39 PM   #88
I just bought a pair of the 1156 white 36 LED board-mounted "backup" lights and a pair of the same in red (1157) from them. I've had these in my hands, "loose" but lit up; they're don't seem to get very hot. I'm gonna install them in THESE late-60's/early-'70's Airstream taillight housings, which i'm gonna subsequently retrofit to my '77 Argosy 20' MH:
My plan is to use some ~1/2" thick styrofoam "blocks" left over from when Stanley Steemer was here; I'll glue 'em into the "cans", and then doublestick tape the LED boards onto the styrofoam. . .
TheGanzman is offline   Reply With Quote
Old 12-13-2005, 10:26 PM   #89
1992 34' Limited
Socket turned!?
Jim -
Thanks for the photos you posted. Helped a bunch. Those you posted seem to be exactly what I have in my unit. Have a question about the socket you purchased and mounted. By socket, do you mean what the bulb actually 'plugs' into. If so, do they just get removed ( easily??) from the back of the factory housing/reflector? If it is more invloved, please enlighten me!?
Sorry for the continual questions but life is CRAZY and when I get into this, I want it to be as easy as I can make it. Not that things with AS's ever are!
Also, the LED's that you got are a plug and go deal, not like the post after you, who referenced a 'board' that he was going to tape to a base within his fixture. Advantage to one or the other???
Glen - do you by chance have a photo of those running light additions??
Thanks everyone!
Love this board!!!!!!!!!!!
Axel
Old 12-14-2005, 07:07 AM   #90
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Marker light conversion
Just uploaded a shot of the new marker lights. Low res image. Take a look.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 12-14-2005, 10:35 AM   #91
The Hawk's Lair
cooperhawk's Avatar
If you wanted to install a bulb somewhere you would drill a certain sized hole and then slide a socket into it. That is the socket I am talking about. On my unit it slid in with a tight fit. I put tape maround it to keep it from jiggling free. If I decide to make it permanent, I will use my mig welder and spot weld it in.
One thing is that you slide the old contacts out of the socket installed in the reflector and use the contacts on the new socket running the wires throu8gh them old socket.
I guess pictures would tell it better. Big snow today and I need to plow but will get more pictures soon.
AKA THE GUNNER
VFW, LEGION, NRA
Old 12-16-2005, 11:57 PM   #92
1992 34' Limited
Photo no go...!
Glen -
Tried to find you lo-res photo but no go... Couldn't find it. Are the running lights you mounted similar to AS running lights that have been mounted for the last 10 years or so? Newer style, older? Thinking that updating the RL to a current style would actually be a good thing. Course, mine isn't that 'vintage', yet...!
Jim - hope you get dug out soon! and looking forward to the photos you referenced. Just to try to get things clearer in my head - did you wond up removing the original 'socket' and replace with a "new" socket? Or where you saying that the "new" socket fit into the original socket with the guts/wires removed??? Sorry for being a dork about this but am trying to visualize your effort. Thanks for hanging with me on this!!!!
Axel
Old 12-17-2005, 05:26 AM   #93
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Axel, try this link. I uploaded these to the general photo library and you would have to have gone to my photos, then selected a photo to enlarge, then you could click on see all GlenCoombe's photos before you could find it. I'm still trying to figure out how to attach photos to posts. It never seems to work for me the same way twice. I've done it in the past put working from 3 different computers is a challenge.
http://www.airforums.com/photo...imageuser=8416
The style is direct replacement of the old "double bull" lens stlye. Sealed 13 LED array. On ebay just search for Calboy1 or go to Superbright to see them or the more streamlined type of smooth lens. I liked the vintage look so went this way.
Old 12-17-2005, 08:26 AM   #94
The Hawk's Lair
cooperhawk's Avatar
The new socket fits into the old socket with the guts removed. It is a tight fit and then I put a wrap of duct tape to secure it from jiggling loose.
Got dug out and now it is COLD!! 5 degrees this morning.
Axel[/quote]
AKA THE GUNNER
VFW, LEGION, NRA
Old 01-01-2006, 05:43 PM   #95
Joe Z's Avatar
LED's Installed in 2003 25' Classic
Received the LED replacements for my '03 Classic as a Christmas present and thought I'd share my before and after pics. The before pic is earlier in the day than the after pic so please take that into consideration when comparing brightness. Joe
ID:	17382   Click image for larger version
Joe Z is offline   Reply With Quote
Old 01-01-2006, 06:51 PM   #96
_
good gift from santa, barkingspider......
it's really hard to demonstrate how much brighter these leds are than the original bulbs.....have you seen them at night? i've been trying to take a nightime photo....but haven't been able to move from the truck brake pedal to the rear end quick enough!!
cheers
2air'
Old 01-02-2006, 12:26 AM   #97
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
cheers
2air'
2air,
To get a night time photo without a helper, just put your hazard flashers "on" and just time your photo appropriately.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 01-02-2006, 08:33 AM   #98
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by 66Overlander
2air,
Or just get a 2X4 and wedge it between the seat and brake pedal. I've even used a partial bag of #7 1/2 shot to weight the pedal down so I could test lights out when I'm alone.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 12:52 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 08:52 AM
