Old 12-18-2006, 09:00 AM   #1
LED Running/marker Lights-Teardrop
Anyone seen or know where to get some LED teardrop marker lights...Old style if possible???
BornToRock is offline   Reply With Quote
Old 12-18-2006, 10:25 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Don't know about those, but if you already have the marker lights, you can go to:
www.superbriteleds.com
and get some LED bulbs to go in there.....
Old 12-18-2006, 12:46 PM   #3
1992 34' Limited
Falls Church , Virginia
Something to consider....
BTR -
One thing to consider about LED's, aftermarket lights in general - many come with only one wire (as opposed to the 2 wire system on SilverToy) using the screw mount as ground. Might not be big deal, but then there has to be a good reason it was done with 2 wires the first time around.
Then again I did a clearance light swap with lights from LEDS-R-US and they do look great. Were about $5 or so a piece. Seems I remember they had tear drop shape as well. They do have a good web site so you could check there.
Hope that helps.
Axel
SilverToy is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 10:30 AM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
