Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-30-2005, 11:16 AM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
LED *Power On* lamp replacement
My power on light keeps burning out since I keep the trailer plugged in all the time.
The bulb is a GE 53X 11.1mm bayonet base. According to Radio Shack Cat#272-1117 it only has a 30 hour life. Although I have found other online sources that boast a 1000 hour life.
I'd like to find an LED replacement bulb so I don't have to worry about it. I found that http://www.superbrightleds.com/led_prods.htm has a lot for sale but I cannot find the 53X replacement. I emailed their tech support.
If I cannot find one, I will add a switch at the fuse box to turn power off to the lamp when at home.
If anyone knows of a source let me know. If I find one I'll report back here.
-Tim
theVAP - Airstream Podcast
Old 03-30-2005, 11:28 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
[QUOTE=Safari Tim]My power on light keeps burning out since I keep the trailer plugged in all the time....The bulb is a GE 53X 11.1mm bayonet base. According to Radio Shack Cat#272-1117 it only has a 30 hour life. Although I have found other online sources that boast a 1000 hour life.[QUOTE]
Tim:
Do you happen to know the rated voltage of the 53X light¿
The ¨power on¨ light in the ´78 Sovereign is also burnt out - measured 6.3 volts across the terminals - does anyone have a source for a long life replacement for this bulb¿
Thanks...
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-30-2005, 11:44 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Not sure if this applies here, but I found that several different types that have the same base will work. It was a while ago, so don't hold me to it. As a matter of fact I thought I found the info on the superbriteled website.
Old 03-30-2005, 02:15 PM   #4
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
The specs from the websites say 14.4 vdc at 120mA.
Tim:
Thanks...
-Tim
Old 03-31-2005, 10:58 AM   #5
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I found one!
I found a direct LED replacment lamp for the power on light in my '71 Safari.
It a little pricey at $8.50 + $7.50 shipping.
It's a high brightness white led lamp that is a direct replacement for the GE-53X. It is a little longer at 1.06 inches when the original is 0.94 inches. But I don't think that is going to be a problem.
It's rated at 100,000 hours life. And draws 36mA. The orignal lamp is rated at 1000 hours for a quality one (30 hours for the radio shack one) and draws 120mA.
Since I keep my trailer plugged in all the time at home, this extended bulb life is what I am looking for. Also LED's run much cooler. The part of the plastic in front of the power on lamp is a little cracked and deformed from the prolonged heat.
If anyone is interested I'll take some pics and post back how it works when it comes in.
-Tim
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Pictures of shell off floor replacement... williamhenshall Repairing/Replacing Floor &/or Frame 23 08-08-2002 05:05 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
