Old 09-05-2015, 11:37 AM   #1
Carbondale , Colorado
LED Light Dimmer
Is there a dimmer available for the LED lights in a 2011 or later AS?
thinairflyer is offline   Reply With Quote
Old 09-05-2015, 12:09 PM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . my 2010 FC28 has dimmers on the ceiling lights, dealer installed I think. Can't think of any reason a 2011 would be different. . .regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 09-05-2015, 02:28 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Look up "LED driver" on Amazon/Ebay.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-05-2015, 03:42 PM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Its not as simple as adding a conventional dimmer to your ac lights or 12v incandescent lights . Hopefully soon technology will make it as easy as swapping out a regular single pole switch.
mayco is offline   Reply With Quote
Old 09-05-2015, 06:42 PM   #5
dznf0g's Avatar
Oswego , Illinois
Call Dan at leds4rv.com. he has several options.
-Rich-
Old 09-05-2015, 06:52 PM   #6
2011 25' FB Flying Cloud
Anywhere & , Everywhere
You can purchase the dimmers Airstream uses in 2012 and later models from Airstream. Since this is not a Airstream specific part you should be able to purchase them direct from the Airstream Store. Give Amy a call on Tues. Be aware they cost me about 42 bucks each when I bought mine 3 years ago so may be more expensive now. Don't think Dan at LED4RV carries these but may be wrong.
Al - K4GLU is offline   Reply With Quote
Old 09-06-2015, 09:36 AM   #7
LED Dimmer
Hey Ramblin Man-Could you send a picture of the Airstream furnished dimmer?
Is there a brand name on them? Actually the paperwork on my 2011 says that it has dimmers but doesn't. Thanks for your help.
Old 09-06-2015, 09:53 AM   #8
2016 28' Pendleton
Hi from AZ. . . yep, can do, but not till Tuesday. . .regards, Craig
WBCCI 2851,4CU
Old 09-06-2015, 06:19 PM   #9
SL4BLLT's Avatar
1972 31' Sovereign
Fort Bragg , North Carolina
Here's what we used for out LEDs in our 1972 Airstream with the sets of lights we installed. Don't know if it is what you are looking for. See attached picture outside switch are above stove tops
Purchased them and had them installed with the lights at Out of Doors Mart back in 2013.
It sells for $14.95
PWM Dimmer 12 volt Knob Controlled 12VKDim
SL4BLLT is offline   Reply With Quote
Looking for a 12V LED Dimmer Switch 66replica Lights - Interior & Exterior 4 11-16-2014 05:20 PM
LED Dimmer Failure? Hoonanea Lights - Interior & Exterior 25 09-02-2014 10:46 AM
2011 LED dimmer upgrade? Getahobby Lights - Interior & Exterior 0 10-25-2012 08:21 AM
Dimmer for LED goshawks00 Lights - Interior & Exterior 4 02-23-2012 12:57 PM
LED Dimmer Over59 Electrical - Systems, Generators, Batteries & Solar 4 02-13-2005 06:57 AM
