Old 07-13-2006, 06:07 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
LED conversion of exterior lights
There has been a post in the Motorhome forum that relates to converting the stop/tail lights to LEDs. I have just finished my conversion on my trailer and thought I would share some info.
I changed all of the marker lights to LEDs that i got from
http://www.florawrecker.com/cgi-bin/...TANGULARMARKER
Then I removed the center back up light and replaced it with a stop/tail light and sequenced all 3 lights with a kit I got from
http://www.webelectricproducts.com/products.htm
I did this for a couple of reasons. I travel a lot after dark and wanted the added brilliants all around. I had previously relayed all the trailer lights off the trailer batteries to reduce the load on the cheap GM wiring. Now I have reduced the load on the trailer batteries as well.
The project can be seen in progress on
http://www.airforums.com/forum...html?highlight
Name:	3 tail lights.JPG
2004 Excursion 4x4
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 07:00 AM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 03:08 PM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 02:30 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 11:30 AM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 12:54 PM
