Old 02-03-2007, 08:58 PM   #1
2005 30' Classic S/O
la mesa , California
Question leaking running lights--any good fixes?
Torpedo shaped running lights. Always have h2o condensation. Any fixes?
vetdr is offline   Reply With Quote
Old 02-03-2007, 09:14 PM   #2
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Replace them - they are cheap
Pop Rivet is offline   Reply With Quote
Old 02-03-2007, 09:58 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, don't replace them. [clearance lights] This has been discussed before and the cure has been to replace the screws with stainless steel screws, add stainless steel flat washers, and an "O" ring on each light assembly.
Take the screw, put on the flat washer, and then install the "O" ring. Next install the screw assembly with the "O" ring against the plastic lense. I have done mine this way and so far so good.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-03-2007, 10:03 PM   #4
cammur's Avatar
Roseville , California
Frustrating, huh?
Do a search and you will find it is a common problem. I've fought it and am down to two lights remaining with a problem. Remove the lens, dry things out thoroughly, rub silicone on the crappy gasket to improve the seal, replace the rusty screw with a stainless screw, try a rubber washer on the screw. Hasn't work every time, but I'm getting there.
Good luck and report your success!
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 02-03-2007, 10:03 PM   #5
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Good Advice...
yep, thats good advice. i actually bought a little kit from LEW the master tech guy who hangs around the forum here (i'm not into hunting down the parts for 13 lights or whatever, he has them in stock). stainless steel washers, rubber O rings and stainless screws... and it was cheap and it works. no more water, no more rust.
k.
Kevbo10 is offline   Reply With Quote
Old 02-04-2007, 01:05 AM   #6
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Moisture in running/clearance lghts...
Hi vetdr and fellow San Diegan…
Welcome to the forums
Here’s one thread on the solution to moisture getting in the clearance lights:
http://www.airforums.com/forums/f4/leaky-marker-lights-how-fix-em-21214.html#post214345
I think we talked about this last August!
BTW, glad the Gorilla Lock worked for you!
SilverGate
SilverGate is offline   Reply With Quote
Old 02-04-2007, 06:53 AM   #7
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I think the screw replacement is the way to go. I didn't have time to find screws so I cleanded my rusting screws and painted them with black ceramic paint and baked in an oven. I used silicon glue to seal the screws when I reinstalled them, no problems so far.
I do like the SS screws and o-ring method just didn't feel like driving around to find the material, I am lazy some days.
Let me add while I had the lights apart I cleaned the contacts and applied bulb grease to all the contacts.
Thanks Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 02-04-2007, 06:58 AM   #8
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Article
Here go:
Nothing difficult and a fine project for an evening while not on the road. All the tools I needed I was able to get from my local auto supply and hardware store. First you will need a Philips screwdriver, a ½ inch plumbers round brush, a small brass brush, a tube of Dielectric grease, clear silicone, #8-32 X ¾ inch stainless screws and #6 nylon washers. Oh, don’t forget the light bulbs, #97 12 V 3CP.
First start off by removing the lens and cleaning off any old silicone and dirt. Remove the foam gasket and place aside. Remove the old bulb and inspect inside the socket. The ½ inch pipe brush fits perfectly into the socket for a good cleaning. Clean the mounting screws with your brass brush removing any dirt or rust. Wipe the entire assembly with a clean cloth, apply the dielectric grease to the contact wall of your new lamp and replace in socket. Next you will want to replace the foam gasket and put a nice thin bead of clear silicone around the lens edge. Carefully replace the lens to the light mounting and wipe any excess silicone away. Before you can tighten with your new stainless screw and nylon washer, put a dab of silicone into the screw opening. This will give you a nice seal on the face of the lens. Don’t tighten too much as to crack your lens and remove any excess silicone from the screw when done. Finished, now only ten more to go!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-06-2007, 03:19 PM   #9
Who is the guy to contact???
Neil Ervin, Sequim, Washington (on the north edge of the beautiful Olympic Peninsula)
neil.ervin is offline   Reply With Quote
Old 02-06-2007, 07:20 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
THAT WOULD BE ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-07-2007, 03:24 PM   #11
cammur's Avatar
Nice description, Rickandsandi, including the screw and o-ring sizes.
I've had a problem getting the screw to tighten adequately without it scrunching the o-ring out of shape, recreating a leak. This may be why some people, perhaps lewster, recommend a stainless steel washer on top of the o-ring.
Cam
2005 25' Safari SS
AIR #8752
Roseville, CA
Old 02-07-2007, 06:56 PM   #12
lewster's Avatar
Yup,
That's why I used the washers between the screws and the o-rings. They provide a nice even pressure to seal the o-ring. BTW, those screws are METRIC thread.
replacement tail lights for '69 Airstream bgow 1969 Overlander 0 08-06-2002 10:03 PM
Running the roof A/C when traveling ... Hayseed Airstream Motorhome Forums 3 07-21-2002 08:16 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 01:58 PM
Running Hot Starman Airstream Motorhome Forums 6 06-27-2002 09:36 AM
Interior lights - 61 Bambi 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 06-07-2002 09:52 AM
