Old 09-29-2007, 04:32 PM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
L.E.D.s meet fiber-optic telltales
Many airstreams have fiber optic telltales that enable the driver to see if the trailer tail and brake lights are functioning. Because they work by transmitting an image of the glowing bulb filament, they become unusuable when the lights are converted to l.e.d.s since there is nothing for the end of the fiber-optic to "see". Now comes the 10mm super bright white l.e.d! A very tidy fix can be accomplished in the following manner that will make the telltales functional with the solid state tail light conversion:
Looking at the accompanying pics. note that: The 10mm l.e.d. will fit in the grommet where the oringinal lens for the fiber optic was, but facing into the fiber. So...
Drill a hole in the end of the l.e.d. to receive the end of the fiber-optic cable and put the l.e.d. in the grommet facing the front of the trailer. Wire it to the supply for the light and use an approprate (470 ohm) dropping resistor. Put the fiber end into the hole you drilled and push the boot over the grommet to retain the fiber. Voila! The best of both worlds
ID:	46205   Click image for larger version
ID:	46207   Click image for larger version
ID:	46209   Click image for larger version
ID:	46211   Click image for larger version
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
electric jack...that darn fiber gear again! JohnGalt48 Jacks, Stabilizers, Lifting and Leveling 30 06-30-2012 02:18 PM
Fiber Optic Indicator Light Cover Ganglin Lights - Interior & Exterior 58 01-10-2008 02:48 PM
Anyone heard of Fiber Floor? 78tradewind Floor Finishes 3 05-31-2007 11:33 AM
Fiber Optics...Coooool!!! Rivetedude On The Road... 14 11-17-2005 09:28 AM
Looking to meet up Ray Pena Forum Rallies & Meet Ups 13 06-28-2005 07:39 PM
