Old 06-04-2006, 06:09 PM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Keeping the telltale while loosing the Univolt
Replacements for the Univolt converter do not supply a tap to run the control panel AC Power ON lamp. A simple, cheap, and expedient work-around is to plug in a "wall-wart" small appliance 12VAC supply (thrift store?) next to the converter and wire one side to ground and the other to the pilot light wire. This will indicate when you are hooked onto outside 110V.
Excella CM is offline   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
