Old 06-22-2016, 01:52 PM   #1
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Jury-rigging shore power at the house
My Airstream (with 30A plug) sits in the driveway near my garage. Power in my garage is limited to two 15A circuits that power the lights and 110v outlets. I would like to plug the trailer in and run the 13500 btu air conditioner. If I use an adapter to plug into one of the 15A circuits, it won't run long before the adapter warms up and the breaker trips. I have looked into just running a 30A circuit out to the garage, but my breaker box is already full, allowing no room for expansion, so in addition to running the line, I would have to replace and rewire my entire breaker box, which gets expensive.
So what I had in mind was to build a jury-rigged pig-tail which would essentially be two extension cords, the male ends of which would each plug into the two separate 15A circuits that are presently in my garage. The female ends would then be spliced together (in a parallel circuit) in a 30A female receptacle, achieving a combined 30 amp capacity.
Anyone see a problem with this? Am I risking breaking laws, burning down my garage, or cooking myself?
Thanks in advance!
Belegedhel is online now   Reply With Quote
Old 06-22-2016, 02:00 PM   #2
Zil
egg harbor city , South Jersey
That is right up there with the most stupid idea this month.
Sorry. You can take a 30 amp circuit out of your existing panel. Move something else to share a different breaker and then install a 30 amp breaker. Use heavy enough wire from the panel to the garage outlet, or you may fry the AC with low voltage.
Zil is offline   Reply With Quote
Old 06-22-2016, 02:23 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
What size is your current box and where is it located. You may or may not be able to put in a sub panel. If you could put in a sub panel in your garage you could move the garage circuits to the sub panel thus opening up space on the main panel to put in a breaker for the sub panel. Then put in the 30 Amp 110 service for your trailer. A 50 amp sub panel would be more then enough
Old 06-22-2016, 02:27 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you take other the Aerowood's approach make sure the fire insurance is paid in full.
2004 Excursion 4x4
Old 06-22-2016, 02:42 PM   #5
Images: 59
I guess I would rate this the #1 idea of the month. At least OP asked the question.
Use Aerowood's method.
Old 06-22-2016, 02:48 PM   #6
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Yes, call an electrician.
This is the strangest life I've ever known - J. Morrison
The Nest Egg - 2015 Airstream International Serenity 27FB
mojo is offline   Reply With Quote
Old 06-22-2016, 03:12 PM   #7
Belegedhel's Avatar
Houston , Texas
I appreciate the constructive response. My house sits on a long skinny lot. The house is in the front, and the main breaker box is near the front corner of the house (can't tell you the size off the top of my head). The garage sits in the very back of the lot, so there is roughly 50 yards between the breaker box in the front and the garage itself.
I did start this consideration by calling an electrician. His recommendation, which I would imagine may be the "best" way to do the job (though not the mmost affordable) was to replace the entire breaker box with one that has greater capacity, and then to run the additional 30A circuit back to the garage and so on. The cost of the job was well over $1000 with other potential inflation involved in hiring out the necessary trenching associated with running the 30A circuit.
This led me to consider a way to use the existing circuits and electrical lines to accomplish a temporary (as I never know how long I am going to be at this residence), yet hopefully safe, configuration. Yes, I know it sounds sketchy--this is why I used the term "jury-rig" as opposed to "DIY-Genius solution" in the title.
Old 06-22-2016, 04:19 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Just because you have 2 outlets doesn't mean you have twice the capacity. They are more than likely wired in parallel and fed by one breaker at the house.
Chances are if you only have lights and a couple of outlets in the garage the wire between the house is WAY too small to run a 30 amp circuit.
For that distance you would probably need #4 or maybe #2 wire to provide what you need because of the voltage drop between the house and garage.
It's better and SAFER to do the job right. Make sure if you hire an electrician he knows the trailer requires 120 volts not 240 volts.
Old 06-22-2016, 04:36 PM   #9
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Let's imagine one breaker serves the two outlets and the other breaker serves the lights. This means you'll have to wire in a third outlet drawing from the lights circuit. With lights out you might theoretically have 30 amps at your disposal. However with a jury rigged cord combining the two there's no way to meter the draw between the circuits to ensure its 50/50. So if for watever reason one circuit happens to be asked to supply 65% of the current it will quickly trip leaving the other circuit at 100% and tripping it too.
I wouldn't do it.
kscherzi is offline   Reply With Quote
Old 06-22-2016, 04:47 PM   #10
1976 29' Ambassador
Atlanta , Georgia
As others have said, you can't. It's likely the outlets lead back to the same breaker in the panel. You can't look at the number of outlets and just add up the amps. It's like plugging in a 6 outlet surge protector and saying you have 90 amps.
Chae is offline   Reply With Quote
Old 06-22-2016, 05:02 PM   #11
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
It's good that you asked about this before you tried it. My advice to you is simply that you contact a qualified electrician in your area and explore your options with him/her. This is too dangerous to try on your own with advice from the Forum.
If cost is a factor (and it appears that it may be based on a subsequent post) my advice would be to consider how badly you really need to run the AC when the trailer is at your house.
Bob Martel
WBCCI# 5766
Old 06-22-2016, 06:02 PM   #12
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Venice , Florida
Send a message via Skype™ to beachbouy
Sounds like a garage fire waiting to happen.
We drag Mitzi a 2016 International Serenity 30, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 06-22-2016, 06:07 PM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thanks in advance!
Well, I think you've found several folks do indeed have a problem with this - some expressed that concern in more dulcet tones than others...
I notice from your profile you're in TX so I can see why you want to run the AC. I would imagine if you shopped around, you could find a qualified electrician to do the work for less than $1K but honestly, that would be a good price to pay to have the peace of mind that it was done right and in essence, "cheap" insurance against a possible catastrophic fire.
Electricity is just one of those things I never want to mess with.
Good luck!
By the way (on edit) this site has a diagram of how it must be wired (some electricians mistakenly set it up like a washing machine outlet...). http://www.myrv.us/Imgs/PDF/30-amp%20Service.pdf
Old 06-22-2016, 06:26 PM   #14
kokopat's Avatar
Hendersonville, NC , North Carolina
Have you utility company put in another service with meter at the garage. I'm sure they want it done correctly.
kokopat is offline   Reply With Quote
Rigging Up A Solar Trickle Charger Chuhhuniban Electrical - Systems, Generators, Batteries & Solar 1 03-28-2016 04:29 PM
Long Term Shore Power and House Battery cbrittan Batteries, Univolts, Converters & Inverters 30 11-02-2015 01:15 AM
jury duty mykabyka Full-Timing 10 09-15-2013 06:40 PM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 06:07 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
