Old 07-11-2016, 02:20 PM   #85
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There has been some discussion on this thread about the damage that could/will happen to an AC that is run on too thin of a line. I expect this is due to running at too low of voltage due to trying to pull too much amperage through too small of a line. Can any of you tell me what the maximum allowable loss is? For example, if I plug my multimeter into an outlet with nothing running, I see 119 volts. If I plug my Airstream into that socket using an adapter and run the AC, the voltage drops to around 112. Is this too much drop, or is it about normal?
Old 07-11-2016, 02:37 PM   #86
HowieE's Avatar
Princeton , New Jersey
Images: 12
Generally anything above 110 is OK
2004 Excursion 4x4
Old 07-11-2016, 02:40 PM   #87
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Ideally there should be no measurable voltage drop.
Most quality equipment is designed for a + or - 10% range. You are pushing the boundaries with what you are reading. The question is: how far does the voltage drop when the compressor kicks in?. And how long does it last? Your meters refresh time is too infrequent to give an accurate reading of that voltage drop. The lower voltage the higher the current to maintain the power requirement. Higher current = more heat.
Contrary to popular belief the electrons do not travel thru the wire, they travel on the surface. The larger the wire the greater the surface area.
Old 07-11-2016, 03:01 PM   #88
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Jury-rigging shore power at the house
Fwiw, in 73 the air conditioner was likely built to run on 110 or 115 volts....
I have researched this some and there is a strong contingency that claims that a about a 10% variance at point of use is ok.
Fwiw, my 72 Armstrong has been running on about 109 volts during peak heat for six weeks this summer, and the same for the two summers prior.
Gradiens super tenui glacie.
Old 07-11-2016, 10:57 PM   #89
Salem , Oregon
Images: 18
Hi, house hold voltages have been stated as 110, 115, 117, and 120 volts. take your pick. Appliances have been rated at all of these voltages.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-12-2016, 10:04 AM   #90
egg harbor city , South Jersey
Except with some very high frequencies. In household power, and low voltage applications, electrons travel through the whole wire, not just on the surface. Else, why don't our wires would look like water pipe?
Zil is offline   Reply With Quote
Rigging Up A Solar Trickle Charger Chuhhuniban Electrical - Systems, Generators, Batteries & Solar 1 03-28-2016 04:29 PM
Long Term Shore Power and House Battery cbrittan Batteries, Univolts, Converters & Inverters 30 11-02-2015 01:15 AM
jury duty mykabyka Full-Timing 10 09-15-2013 06:40 PM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 06:07 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
