Old 06-23-2016, 05:21 PM   #43
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
Most homeowner insurance company's get upset when your house burns down and they find electrical work that does not meet code.
PeterKV is offline   Reply With Quote
Old 06-23-2016, 06:52 PM   #44
Always lost?
1975 31' Excella 500
Chestermere , Alberta
Another option no one has mentioned would be to wire an extension cord to plug into the dryer recepticle of the home. it is a dedicated and protected 30 amp 240 volt circuit. only using one phase of the plug to run the AS. laundry may pile up but the AC will run.
news2me2 is offline   Reply With Quote
Old 06-23-2016, 07:00 PM   #45
Always lost?
The best option would be to mount a 50a 240v sub panel to the garage. Get your electrician to do your connections but run the wire yourself. this will save you a ton of $$$$. run 6/3ga wire from electrical panel to garage. easiest way is to rent a trenching machine from (HD,Lowes,rental place) spend an afternoon running the wire (easy job but time consuming when paying someone buy the hour to do). then the sparky can do your hookups in an hour or 2 and you are set for anything in the garage. HUGE selling feature for the home as well in the future.
Old 06-23-2016, 07:15 PM   #46
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
There is a lot to AC power that many of us do not know. About two years ago someone shared an adapter that they had purchased to use on their generator on the forum. I found that the product had been removed from the market for safety reasons. I too was trying to use both outlets on the generator but my father, mr electric, laughed and talked about how you cannot always do that because of phase and other issues. Don't mix electrical sources he said just remember that ok? So, he started my generator and found that both were actually in phase but regardless he said, it isn't necessary as the generator will output the max to one plug anyway.
Houses are different as are circuits- like a different source. Anyway, I feel for you. Hope the best with the electrician.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-23-2016, 07:28 PM   #47
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
"Jerry-rigging" and "30-amp service" are not happy to co-exist in the same sentence ... much less in reality. I am glad you asked before leaping ... hire a pro. You will be far better off. We understand wanting AC for your rig at home, as we are in AZ ... we hired an electrician to run a 30-amp line run to our trailer and it was one of the smartest things we have ever invested in for our rig. We have never regretted it ... and now our Bambi can remain in a non-melting state even in 100+ degree weather.
Good luck!
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Old 06-23-2016, 07:37 PM   #48
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Lots of great information/opinion exchange going on this thread, and I appreciate all of the participation as it gets me thinking of alternative options.
So a bit more information: My main breaker box, as mentioned earlier, is mounted near the front corner of the house. It is a 200A box, and the meter is right next to it.
I do have a correction to earlier mis-est some space in the bimates: Distance from the box to the garage is 104 ft.
Between my main power cord and an extension, I have enough to reach the back of the house, so maybe a conduit run along the length of the house to a 30A female could be a safer alternative...
Old 06-23-2016, 08:06 PM   #49
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Throw in a double breaker or two and make some room.
Sounds like your electrician was including the BPCF (Boat Payment Correction Factor)
Old 06-23-2016, 08:07 PM   #50
2007 22' International CCD
And a lot easier to have installed.
KE4GNK/AE
Old 06-23-2016, 08:47 PM   #51
aftermath's Avatar
Spokane , Washington
JimGolden has your solution. Take out the two circuit breakers that go to your garage and replace them with the slim line splits. They will go back into the box leaving you an open space. Use this to place a new 30 Amp breaker and run your line to where you want to install the new outlet.
Make sure you research the size of wire needed to carry the 30 amps through the distance you need. While reading all of this I was wondering how large is the wire that services the circuits in your garage? In home wiring, without special cases or distances, a 15 amp circuit is usually carried on a 14 gauge wire while a 20 amp on a 12 gauge wire. A 30 amp requires a heavier wire and even heavier if going a long distance.
My house was built in 1924 but it did have a "new" 200 amp box installed somewhere in the 70's. We have had a new kitchen done, a new furnace and two new air conditioners. Each time the electrician swapped out the old circuit breakers with the newer splits. Always done to code and always passed. No problems.
aftermath is offline   Reply With Quote
Old 06-23-2016, 08:55 PM   #52
aftermath's Avatar
Here is something you might find interesting.
http://www.myrv.us/Imgs/PDF/30-amp%20Service.pdf
Google voltage drop charts and see what gauge wire you will need. A 30 amp circuit runs nicely on a 10 gauge wire but only to around 25 feet. At 100 feet I think it said 8 but 6 might be better...Lots of stuff here to read about wire size, load and distance.
Old 06-23-2016, 09:35 PM   #53
1977 31' Sovereign
Lynnwood , Washington
To be honest, I think you're asking for trouble.
30 amp is 30 amp is 30 amp. PERIOD.
It's not a good idea to Mickey Mouse this connection. If you have to, call an electrician.
Stick with the proper connection that engineers intended. You'll be glad you did.
Tom
TomKirk is offline   Reply With Quote
Old 06-23-2016, 09:56 PM   #54
1989 34' Excella
Olympia , Washington
The two outlets could be wired to opposite sides of the main power line, which would mean the hot leads (the black wires) would have 240 VAC across them.
Absolutely don't mess with a jumper plug to bridge the two outlets.
You may be able to install 1/2 width breakers to open up some space in the panel, without rewiring the whole thing. You can get 1/2 wides for most brands.
Then you could add a proper 30 amp new circuit. 10ga if short distance, 8ga if long distance.
However if your panel is FPE Federal Pacific Electric, then call a good electrician, because FPE breakers may not drop out even in a total short circuit, I have had it happen personally!! Replace a FPE panel if at all possible.
DaveR-WLYH is offline   Reply With Quote
Old 06-23-2016, 11:01 PM   #55
FPE dual breakers are also very bad. They don't pop either.
KE4GNK/AE
Old 06-23-2016, 11:09 PM   #56
1990 32' Excella
jonesboro , Arkansas
One way to save on job is to buy correct size wire for job. Get an electricians recommendation for that. Call the # for safe digging I think it's 811. They will come out and mark all underground wires and pipes. You can rent a trencher that you can handle and trench and lay your own wire. That would save a lot of labor costs . Than the expense would be for the electrician to do the final connections at garage and panel.good luck.
joel is offline   Reply With Quote
Rigging Up A Solar Trickle Charger Chuhhuniban Electrical - Systems, Generators, Batteries & Solar 1 03-28-2016 05:29 PM
Long Term Shore Power and House Battery cbrittan Batteries, Univolts, Converters & Inverters 30 11-02-2015 02:15 AM
jury duty mykabyka Full-Timing 10 09-15-2013 07:40 PM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 07:07 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 09:23 AM
