Old 06-18-2017, 12:50 PM   #1
Oldsalt47
John Oliver's Avatar
1985 31' Sovereign
Severna Park , Maryland
"Jumper" for trailer running lights
I have seen an advertisement somewhere recently for a small "jumper" type device which plugs into TT wiring harness and allows the TT running lights to be displayed while the TT is disconnected from the TV.
I know this can be done, not exactly sure how, with a short piece of # 10/12 wire, but really like the idea of the jumper.
Anyone else seen this or have any ideas
John
" Judgement comes from experience, experience comes from bad judgement." Simon Bolivar
John Oliver is offline   Reply With Quote
Old 06-18-2017, 01:11 PM   #2
1976 31' Sovereign
Oswego , Illinois
Smile
John
Numerous threads how to do. Easiest is place 10 amp flat auto fuze not mini but reg.size in 11 oclock and 1 oclock slots in car end of umbilical cord. No need to pur. expensive versions.
Old 06-18-2017, 01:32 PM   #3
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Fuse solution -and safe
Hi,
Wondered same when we first got our 25ftss and thought how "brochure like" to sometimes Fire up the running lights in complete quiet.
Push fuse 10-15 amp with slight twisted ends to match the harness angles bridging terminals either side of cord Marker protrusion for a +12v jump to running lights terminal. Could use Less amp fuse if LEDs.
Works great and safe!
Vantair is offline   Reply With Quote
Old 06-18-2017, 03:37 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
If you want to get fancy, you can put a car flasher in the plug instead of a fuse to have flashing lights.
CRH is online now   Reply With Quote
Old 06-18-2017, 08:36 PM   #5
2016 30' International
redondo beach , California
Originally Posted by Vantair View Post
...Push fuse 10-15 amp with slight twisted ends to match the harness angles ...
Thats the trick!
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 06-19-2017, 04:51 PM   #6
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Or you can use a 7-Way Vehicle End Connector to make up one like this with a switch on it.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 06-20-2017, 10:55 AM   #7
EarStreaming's Avatar
2016 23' Flying Cloud
Hillsboro , Oregon
Oh this looks fun to do I'm sure the kids will enjoy all the lights surrounding our AS Now I need to search for that 7 way switcheroo!
EarStreaming is offline   Reply With Quote
Old 06-30-2017, 01:27 AM   #8
And it will keep the dirt out while camping!
Randy and Beth
Direct tv jumper cable dickschaak On The Road... 2 11-01-2015 04:22 PM
Power my '79 with jumper cables? Gasgano1979 Batteries, Univolts, Converters & Inverters 6 03-28-2013 01:57 PM
TV battery jumper to tongue jack. Turtle Electrical - Systems, Generators, Batteries & Solar 16 08-26-2011 03:17 PM
Charging 12V using TV and jumper cables? Boondocker Electrical - Systems, Generators, Batteries & Solar 21 06-19-2007 10:47 AM
