10-03-2006, 11:29 PM
1963 22' Safari
Aurora
Is this a Power Inverter?
Can anyone out there tell me if this is an old power inverter? It's located under the sink of my '63 Safari. I don't think this is a Univolt power system, so I am left to wonder if it's an abandoned inverter? It is a 5"x5"x4"h silver perforated box that has 2 nuts (presumably for the cover) and 1 hole with a bunch of wires going in and out of it (see my previous post for the wiring diagram). The only thing it says on the box is "Suburban Manufactering Company" at the top.
Anyways, it was suggested to me that this is a broken power inverter, which is why some of the wires coming out of the box are currently disconnected. If this is an inverter, can I just replace it with a modern 12V inverter? I plan on keeping my loads to a minimum. i.e. NO vacuums, microwave, espresso machine, laptop, dvd players, or computers.
Thank you!
a.Z.
...life is good
10-04-2006, 04:31 AM
1973 Argosy 26
Norristown
, Pennsylvania
Is this a power inverter?
Hello Aaron; For some of us that are not familiar with the way things looked in 1963 it is hard to determine what it is. However for those of us who can make a determination by the wiring schematic visable on top of the unit which however is not legible in your pic. Posting it as well, would have helped to identify it. You need to keep in mind that since 1963 PO could have installed many different things many times over. Wiring could have been altered as well. Playing a guessing game with electrical systems can be very dangerous. You may not be able to run fast enough when the battery explodes in your face, or the trailer catches on fire. There is a old joke, quote; How long does the electrical short last? answer; untill the fuses/wires burn thru, or the source of power is exausted. My recommendation to you is that anything that is close to fifty years old should be replaced anyway for a piece of mind. Your safety should be valued at much higher level than the cost of a new power inverter. I own a boat business and we deal with all sorts of abortions when it comes to electrical systems, we are especially cautious where you cannot see and track wires. My GOLDEN RULE for employees is; source of power must be disconnected and Ohmmeter must be used. If you ever seen what we deal with, you would value my rule. Do it yourselfers will do anything and everything and when they get in trouble, it comes to us.
If the item in your pic was disconnected there must have been a reason and you do not know what the reason was. Since you cannot safely test the unit it is much cheaper to buy a new one, than to have a professional check it out for you. In the end it may turn out to be not worth repairing and you waste your dollars on checking it out. Be safe and good luck, "Boatdoc"
10-04-2006, 09:47 AM
West of Fort Worth
Boatdoc's advice is good.
BTW - what DO you intend to plug into your inverter if you get one??
10-04-2006, 10:40 AM
Retired.
, At Large
No, it is certainly not an inverter. There are 110v wires going into it, if it were an inverter, there would be a 110v plug on it to plug in something running on A.C. power.
10-04-2006, 12:01 PM
1963 22' Safari
Aurora
Coffee pot, iPod charger/docking station, maybe an electric blanket during the colder months. Not a lot of draw, overall.
So if it's not an inverter, what is it? It looks stock, and I think it's disconnected because it's broken? Surely someone out there has one of these working in their A/S and knows what it is!
I'll work on getting a pic of the 1-line on the cover to share with the forum to help figure this one out!
Thanks!
...life is good
10-04-2006, 12:36 PM
New Borockton
, Alabama
I honestly don't know what it is but I know battery emulators were popular for those that used there RVs as a park model. Can't tell if there are any 12 volt lines going to it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
10-04-2006, 01:45 PM
Jupiter
You still have a beautifully intact schematic on the top of that "box" - take a picture, even if you dont have zoom take the picture from closest listed distance allowed and I will crop the schematic part from it and enlarge it!
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
10-04-2006, 01:46 PM
1963 22' Safari
Aurora
I don't know what a battery emulator was used for, but from what I can deduce, the "mystery box" appears to have both 12V and 110V action going on. I have attached my own wiring diagram to help visualize this rat's nest.
There are (3) wires tied into the box:
Wire #1 is made up of (2) brown wires that tie into a 110V line that appears to lead back to the circuity breaker.
Wire #2 is a pair of red and white wires that tie into a 3-position switch located under the sink. Not sure what this switch is for?
Wire #3 is a single black wire that is disconnected.
I bought this trailer in July, and it has obviously not been connected to a battery for a very long time now. I'm trying to figure out which wires belong where and how to get the 12V system up and running again. While it's very good advice to just leave everything alone and disconnected, I feel that I am doing myself an injustice in not gaining a fully understanding of my trailer and the associated systems. This was obviously all original wiring and had SOME sort of purpose and meaning, one that I would like to get to the bottom of!
Thanks!
...life is good
10-04-2006, 01:47 PM
1963 22' Safari
Aurora
I will get a picture of the schematic on the top of that box and post it tonight!
...life is good
10-04-2006, 02:57 PM
1971 21' Globetrotter
Arvada
It sure looks like you need to rewire your trailer to clean up several years worth of modifications and changes that were all cobbled together. Alot of work but not difficult.
Kip
Arvada ,Colorado
10-04-2006, 03:51 PM
1963 22' Safari
Aurora
Kip -- that's sorta the path I'm heading. Though the existing wires are in pretty good shape, so I'd like to salvage what I can without pulling new wire. For me the biggest challenge is figuring out the original intention of the A/S wiring (since I don't have a wiring diagram to work from) and bringing my trailer back into good graces with the 12V electrical system. On a positive note, it's only the 12V system that's out of whack. My city power works perfectly!
...life is good
10-04-2006, 07:04 PM
Arvada
I,d be more then willing to come over and give you some pointers when I get back to town, another week to go before I,m back in Co. PM me and we'll set up a time. We can ring out the wires and see what goes where and possibly save some of it.
10-04-2006, 08:01 PM
Retired.
, At Large
I don't know what a battery emulator was used for, Thanks!
A battery emulator was used in place of a battery when camping long-term, rather than draining and recharging the battery continuously (there were no converters back then). You would plug it in, and it would supply 12 vdc for lights, the air pump for the water system, fans, etc. Your furnace may or may not need 12 volts for the thermostat.
Maximum output was usually 10-15 amps.
10-04-2006, 08:55 PM
New Borockton
, Alabama
They were also used with non regulated converters that need a battery to filter the dirty power they produced. I actually saw one on a dealer shelf in the last year or so and the ole boy wanted over $200 for it. It was a little dusty!
888-828-1893
Bestconverter.com
10-04-2006, 10:56 PM
1963 22' Safari
Aurora
Aerowood -- I would love to tag up! I don't think I know how to PM, though? Is that personal mail? Anyways, let's get together here in D-Town when you are back and available!
...life is good
10-04-2006, 11:08 PM
1963 22' Safari
Aurora
Great news, everybody! I went and took some pictures and explored this mysterious silver box a bit more. And the answer is.......
......it's a "Converter Box". Yes, my '63 Safari has a converter box installed between the breaker panel and battery. I believe it's purpose is to provide power to the furnace, whether 110V or 12V. I've added some pics to the bottom of this string -- take a look, let me know your thoughts.
If you look at the wiring diagram, it is clear that 110V power comes into the box through the "twin black wires" and 12V comes into the box through the (1) black wire (that is currently disconnected). Then it leaves the box via the red and yellow wires and heads off to the furnace, stopping at a switch first. What is interesting, though, is that there is one 3-position switch under the sink that is not labeled, and another 3-position switch on the furnace that is labeled "ON - 115V A.C. or OFF or ON - 12V D.C. Battery Only". Why are there two switches for the furnace?
Oh, and by the way -- the converter box is still hot. I found this out tonight working with the power on. One of the "nuts" touched the side of the metal box and sparked!
So, do I need this box ONLY if I want to run the furnace off of the battery power???
...life is good
10-05-2006, 03:55 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Aaron,
If you run a search under Univolt you will get good general information. Typically a Converter (what you have) "converts" 110v ac current to 12v dc. It will run the furnace blower, water pump (if you have one) and any 12v lighting you happen to have. In many cases it also charges the battery when you are plugged in. Unless you are doing a restoration, and want to keep everything totatly orginal I would consider the possibility of upgrading to a newer unit.
Aaron
WBCCI #XXXX AIR #2495
10-05-2006, 04:49 AM
Retired.
, At Large
PM= Private Message. If you want to send a Private message, or PM, find the user name you want to PM, click it, and scroll down through the options until you find the area that says: "send a private message to xxxxx", and click on it. It will open a screen similar to what you use to type a reply in a thread. Type your message, and hit the "send" button below the window, and you're off to the races. A search of the forum support and how-to's goes more in-depth.
10-05-2006, 08:22 AM
1963 22' Safari
Aurora
So if I understand this correctly, this "power converter" box is bringing in 110V power from my breaker panel and stepping it down, or "converting" it to 12V so that my 12V fixtures (furnace, water pump, etc.) can operate while I am plugged into the grid. Is this a correct assessment? Is my heater really a 12V unit?
...life is good
10-05-2006, 09:12 AM
2002 25' Safari
Dewey
Yes the heater runs on 12 volts. Also the converter converts the power from AC to DC.
Richard
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
power boosters
John |
Our Community |
18 |
11-19-2002 03:54 PM |
B190 Coach power problem
Luckydog |
Sprinter and B-van Forum |
21 |
11-12-2002 12:59 PM |
Inverter problem
Don McKelvay |
Electrical - Systems, Generators, Batteries & Solar |
2 |
11-03-2002 05:40 AM |
Another Power Jack Question.
68 Suburban |
Jacks, Stabilizers, Lifting and Leveling |
3 |
10-15-2002 10:23 PM |
no power
Mike |
10 |
08-20-2002 06:38 PM |
