Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-27-2006, 04:11 PM   #1
Profile:  1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Is the univolt charger have automatic shutoff?
Or will it over charge batterys?
I have a 12 volt automatic deep cycle battery charger would it be better to hard wire that into fuse panel it is alot quiter and it gives output of the same amps @5.60 amps..
Mrcrowley is offline   Reply With Quote
Old 05-27-2006, 04:48 PM   #2
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Mrcrowley, the older Univolts, such as what you have in your coach, are notorious for overcharging and boiling the electrolyte out of a battery. I just replaced mine, not to long ago with a Progressive Dynamics Intellicharger, with Charge Wizard. Use the "search" function for "Univolt" and you will be reading for a long time!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 05-27-2006, 04:56 PM   #3
Images: 33
How much did that run you Pick ?
I was just thinking allso the univolt runs the 12 volt system when plugged into trailer part pole to so a standard battery charger would not handle that well at all...
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 06:52 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 11:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 05:13 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
