Old 01-24-2006, 06:33 PM   #1
1965 26' Overlander
Acworth , Georgia
Is the 4 wire cable needed for Shore?
I am redoing 65 overlander. IS the 4 wire, 220 volt cable needed at shore hookups? Can't I replace with lighter, new 3 wire 120 volt cable with 3 prong plug?
I do not have nor will have anything that runs on 220v.
PhilMateo is offline   Reply With Quote
Old 01-24-2006, 06:41 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Your coach should be wired for 120v 30A service. You should have no 240 volt service, unless it was added by a P.O.
I bought wire and a 30A RV plug (the RV part is critical, if you use standard 30a plug, it won't fit the plug at the campground) from Ace Hardware, installation was easy The wire is three conductor, not four.
Information needed on Passport America John On The Road... 8 03-07-2004 07:22 PM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 03:17 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 08:52 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 09:25 PM
Wiring Diagram Needed 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 07-29-2002 01:21 PM
