Old 10-24-2010, 05:07 PM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Is my circuit breaker bad.
I turn my breakers on then turned fan on and breaker trips . I reset it and five seconds later it trips. I unplug everything reset circuit breaker and it does not trip I plug fan back in and 15 seconds later it trips. Is this the sign of a bad Circuit breaker? I hope so because ill go on a Chipmunk hunt if it is not if I did not mention I had a chipmunk infestation last winter I hope they did not get a hunger for wire insulation. I do not want to go on a wire hunt after I just got done putting my ceiling all back together and it did work over summer.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 10-24-2010, 05:16 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
have you tried plugging something else in same outlet, have you tried plugging fan in somewhere else?
Old 10-24-2010, 05:22 PM   #3
1977 31' Sovereign
Images: 33
Yes the outlets on in the front except on for the Converter work so the one for the refrig works the one next to sink do the one across from the sink under windows does but the ones in the sleeping area and bath do not not so which breakers works which outlets.? some work some don't the ones in the front work the ones in the back don't to be put simply
K/N Cool intake air
Duel power exhaust
Old 10-24-2010, 05:25 PM   #4
x
XXXX , XXXX
WHAT are you trying to say!
wasagachris is offline   Reply With Quote
Old 10-24-2010, 05:42 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
One breaker can control more than one outlet, use a test lamp, verify which outlets are on each breaker. Only other variable would be ground fault circuit.
Old 10-24-2010, 05:42 PM   #6
A 77 service manual would answer all your present questions, and hundreds more in the future.
Old 10-24-2010, 05:57 PM   #7
1977 31' Sovereign
Images: 33
Ok Is my breaker broken in simple terms?
K/N Cool intake air
Duel power exhaust
Old 10-24-2010, 06:03 PM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I am so confused....
Old 10-25-2010, 08:24 AM   #9
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
yes, find an electricion.
Old 11-13-2010, 09:10 PM   #10
1973 31' Excella 500
Phoenix , Arizona
Where is the breaker loctaed?
kuhldeville is offline   Reply With Quote
Old 11-14-2010, 05:59 AM   #11
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Post 2 starts you in the right direction. Since the problem starts with the fan, so should you. Plug the fan in every outlet you have. Does whatever circuit breaker trip for the particular outlet it is in? You could just need a new fan.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 11-14-2010, 06:13 AM   #12
x
XXXX , XXXX
Kuhldeville the circuirt breaker panel box is located ubder the roadside bed in a center bath model and on a rear bath model it will be located in the bathroom on the roadside.
Old 11-14-2010, 06:23 AM   #13
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Breakers have been known to fail, But is not common.
Try something else in the same outlet that is tripping the breaker. If it does not trip, it is the fan. If other things makes it trip, it is either the wiring or the breaker. Replacing the breaker would be the easier thing to do first. If it still trips then Alvin, Simon, and Theodore chewed some wires.
GeocamperAS is offline   Reply With Quote
Can't reset circuit breaker evamcmahan Electrical - Systems, Generators, Batteries & Solar 2 03-21-2010 08:54 AM
Help finding a circuit breaker. Majikwiz Electrical - Systems, Generators, Batteries & Solar 1 12-11-2009 08:31 PM
Resetting circuit breaker? 68Glbtrotter Electrical - Systems, Generators, Batteries & Solar 4 11-02-2005 06:19 AM
Circuit Breaker Happycampers Electrical - Systems, Generators, Batteries & Solar 4 07-26-2003 06:51 PM
New circuit breaker strip FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:25 PM
