Old 05-17-2016, 11:11 AM   #1
2012 23' Flying Cloud
Tucson , Arizona
Is 30 amp really needed
I have a 30 amp service set up for my 2012 sport. I've heard you cannot run the AC unit with anything less. I recently turned on my AC unit and checked the amperage when the compressor turns on, the most it draws is 14 amps, and not for very long. My question is why does airstream say the AC unit will be damaged if it is not run on a 30 amp set up?
Trace
tracenuttall is offline   Reply With Quote
Old 05-17-2016, 11:33 AM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Remember that your draw from the AC is not the only thing in the RV drawing current. That's where the crunch comes. If you use other appliances -- especially ones that draw a lot of current like hair dryers, microwaves, electric heaters and others -- then you can rapidly reach the limit. And that can be pretty ugly for a unit that runs a motor like the AC.
For many folks, 30 amps are just fine with just a bit of awareness. Running the AC on less than 30 is tricky, tricky, tricky.
Lynn
WBCCI 21043
Old 05-17-2016, 11:52 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would suggest the next thing you buy for your Airstream is a plug in volt meter. Low voltage is what will kill the AC compressor. Even with a so called 30 amp service in mid summer on a hot day you may see low voltage and want to turn the AC off. The older AC units came with a low voltage indicator light and I have seen mine on many times in the summer in campgrounds that claim 30 amp service.
Anything below 105 volts is asking for problems.
2004 Excursion 4x4
Old 05-17-2016, 12:22 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Airstream is in CYA mode on that one.
You might need 30 Amps to run your whole trailer at once and/or while charging the batteries from a heavy state of discharge, but 30 amps to run the A/C and a few lights etc, no.
I have run my air conditioning on 20 amp circuits daily for months on end.
I have an amp gauge that I built in, running normal lights, television, air conditioner, and a hair dryer at the same time flirts with a 30 amp draw.
Superat stultitia.
Old 05-17-2016, 01:25 PM   #5
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
Trace
I have a 30 ft classis. I keep it powered to a Standard ground fault outlet with a 20 amp breaker. My digital volt meter inside the airstream shows 120 volts with nothing else electrically engaged. If I turn on the rear 13.5 AC the voltage meter reads a steady 115 volts, which I'm told is sufficient to run the rear AC. I am reluctant to run the unit for any length of time until I further research the issue. Maybe the experts on this forum can weigh in!
Sjcjr is offline   Reply With Quote
Old 05-17-2016, 01:49 PM   #6
HowieE's Avatar
Images: 12
115 volts is safe to run the AC. There are 2 issues here. Low voltage under 105 and high current over 17 amps. Low voltage will cause motor failure in the compressor after prolonged running. High current will cause the breaker to trip. The second tells you right away. The first just costs a lot of money.
Breakers are designed to trip at about 80% of rated current. If the breaker did not trip on the starting current, higher than running current, it should hold while running. Again it is prolonged running at low voltage that is the problem. This is a silent killer.
2004 Excursion 4x4
Old 05-18-2016, 03:02 PM   #7
1973 31' Sovereign
Middletown , California
Watch out when using adapters to plug into a standard 120v outlet. They melt very easy when using any high power devices! . It never hurts to feel the plugs to make sure they are running cool and this is especially true if overnighting in somebodys driveway. Even 30 or 50 amp plugs will get warm if the outlet contacts are a little flakey at an RV site. A plug in volt meter like a kill a watt is nice to have and I used to keep one where my coffee pot plugged in even though it monopolized the outlet. In a lot of locations the voltage from the power company will vary throughout the day, where I live now it goes from 127 down to 108 but averages out to 120 volts.
ijustlee is offline   Reply With Quote
Old 05-18-2016, 03:19 PM   #8
Trace
Having the ability to safely draw 30 amps @ 125 volts AC, is a HUGE PLUS.
Airstream strives very hard to provide you with things that are above normal or average, instead of below.
Should the supply voltage drop. t then increases. This is why using a cheap extension cord, can contribute to ruining your AC
Keep in mind, that the UNIVOLT is always in the circuit and always draws some current.
Using the AC becomes very border line, if you also want to use an electric toaster. Some electric frying pans can also draw large amounts of current.
Be thankful, that Airstream strives to go a step ahead, instead of behind.
That's why Airstream has the popularity that it has.
Always a little more, instead of a little less. Works for most everyone.
Old 05-18-2016, 03:49 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Trace
14 amps running, it uses a whole lot more than that starting up. Along with whatever else may be on in the trailer. The converter can grab a good bit of power when you first plug up if the batteries are a bit low. The system is designed for 30 amps, feed it less and your risk damaging something.
Aaron
WBCCI #XXXX AIR #2495
Old 05-18-2016, 04:51 PM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Aaron
14 amps was starting up. They said it dropped very quickly.
2012 Dodge Durango Hemi/AWD
Old 05-19-2016, 02:54 AM   #11
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Not possible! Just evidence that many people are less than informed about electricity and electrical appliances. Starting current for induction motor devices like compressors is 3-5 times running current. A 13.5 or 15k BTU AC unit is going to draw far more than 14 on starting surge, but either he or his meter is not seeing it. I would believe 14 running. While it might be fast enough to not trip his breaker, the voltage is going to drop significantly for an instant. I would also wonder about his running voltage.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-19-2016, 03:42 AM   #12
sandlapper's Avatar
1993 34' Excella
York , South Carolina
What is the start up draw and then the run draw of a 15k AC?
Is there or was there such a thing as a 15.5 AC?
Thanks. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 05-19-2016, 04:19 AM   #13
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
The panel inside my 20' has a 30 amp main breaker feeding 4x 20 amp breakers. One of those is for the air conditioner, another for the converter, and the other two for the electrical outlets.
If the air conditioner tries to draw more than 20 amps, wouldn't it throw its breaker at the panel?
I know, I know, voltage drop, other draws, etc. But if I can supply 20 amps 120V to the trailer (properly rated cord and adapter, good city electric service) and control the other electrical draws (turn off the converter and use the house batteries for DC, remember no to dry my hair, microwave popcorn, or make toast), is there some other problem I am overlooking?
teagues is offline   Reply With Quote
Old 05-19-2016, 04:52 AM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The air conditioner draws 18 amps at 120 volts, assuming no mechanical or electrical problems. It can be run on a 20 amp circuit, if there is absolutely nothing else on that circuit. Not even the converter.
Really, really new Bambi! Pahaska Off Topic Forum 3 05-12-2009 08:20 AM
Really, really new!! Globeville Member Introductions 6 08-20-2007 03:33 PM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 08:46 PM
Really really great site and Airstream FrankR On The Road... 5 07-14-2002 02:10 PM
