Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-05-2007, 02:06 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Inverter wiring
I'm getting close to wiring the inverter in the Ambassador. Maybe this weekend.
I'm going to have it power two LCD tv's and a dvd player when boondocking.
My current plan is this. In the battery closet, I'm going to seperate the wiring that powers all the outlets on the curbside of the trailer and wire up a 20 amp rated plug to it.
Next I'm going to wire an AC oulet in the closet and an inverter powered outlet right next to it. So when the trailer is plugged in at a campground for example, I'll move the plug (which powers all the original curbside outlets) to the AC outlet from the breaker box. Thereby restoring AC power.
If we are not hooked to power, I'll manually move the plug over to the inverter outlet.
These outlets do not power the converter, fridge, ac, or microwave, so I don't have to worry about that. And I won't have to move the plugs around on the a/v equipment. The only problem is the AC lights are on this same circuit so we'd have to remember not to use them when on the inverter. And the bathroom outlet is on it, so we'd have to leave the hair dryer and curling iron off!
Any thoughts?
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 01-05-2007, 02:25 PM   #2
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 73
Just one thought
Originally Posted by Safari Tim
...Any thoughts?
Get member Roadkingmoe to bless your final plan. He appears to be very good with inverter applications.
Tom
Old 01-05-2007, 06:15 PM   #3
Jacob D.'s Avatar
Profile:  1964 26' Overlander
Oakland , California
Sounds OK to me, but depending on the size of inverter I'd be concerned about having no circuit breaker protection when running from the inverter. If it's a 200W, well, it's probably no big deal, the inverter will blow up before the wiring will melt if there's a short-circuit. If it's 2kW, I'd really want a circuit breaker in there.
A manual, hardwired transfer switch connected before the breaker box (i.e. just after the 30A service enters the trailer) would keep the circuit breaker protections and be easy to flip over. Probably $50 or less. Or you could put it where you're currently thinking of putting the plug & outlets if you're OK with bypassing the circuit breaker panel (or you could add a small breaker right after the inverter, before it's connected to the switch).
Jacob D. is offline   Reply With Quote
Old 01-05-2007, 07:02 PM   #4
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Tim,
I was in a 2007 23' Safari last month and they had a factory installed inverter. The inverter was activated by a switch and ran only certain separate, marked outlets. Have you considered this? That way you would not accidently use too many appliances or forget to transfer power from the inverter back and forth to shore power.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 01-05-2007, 08:02 PM   #5
Safari Tim's Avatar
Images: 35
It's an 800 watt inverter and it has overload shutdown protection built in. So, I assumed I would not need a breaker on it.
Bill, that is sort of what I'm doing by isolating the inverter to one circuit instead of the whole panel.
-Tim
Old 01-05-2007, 08:24 PM   #6
wkerfoot's Avatar
1954 29' Liner
Orange , California
Tim,
Not the way I understood what you propose. I thought you said that the outlets would be powered be either shore power or inverter power depending on where the plug is. In my example, the inverter outlets are dead unless the inverter is on and shore power can never power those outlets.
Bill
Old 01-05-2007, 08:32 PM   #7
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 35
Tim,
Have you figured out how much battery draw you are going to need to run the inverter? It takes 10 amps of battery for every amp of 120 volts you produce. The attached chart shows the battey life when running various devices.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 01-05-2007, 08:54 PM   #8
Profile:  Webster , New York
Tim
Use a good heavy 12 gauge cord on your transfer plug.This way you wont have a undersized link when you are hooked up to shore power and useing your high draw appliances.
Doug
bibbs is offline   Reply With Quote
Old 01-05-2007, 09:02 PM   #9
Safari Tim's Avatar
Images: 35
Here is my artistic rendering
The outlet on the right is fed by the breaker box and 15 amp breaker.
The outlet on the left is fed by the 600w inverter with built in overload and overtemp shutdown.
The wiring and plug added are rated for 20 amps.
So the idea is that I will manually plug in to which ever power source I need at the time. No electric hookups, I'll use the left outlet. When we have electrical service, I'll use the right outlet.
-Tim
Old 01-05-2007, 09:07 PM   #10
Safari Tim's Avatar
Images: 35
Tim,
Well, both LCD TV's draw about 50 watts each. Have not looked at the DVD player yet. So that would probably around 15 amps
Maybe we should bring a flash light and a deck of cards instead
Originally Posted by bibbs
Tim
Doug
Thanks Doug. I actually picked up a 6' heavy duty 12 gauge exension cord with a right angle plug.
-Tim
Old 01-05-2007, 09:11 PM   #11
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Tim,
Anytime you have a sharing of an electrical component in an RV, you should have a transfer switch that will eliminate ANY possibility of ever having the 2 inputs connected at the same time. From your diagram, it appears that the outlets leading from the breaker box can be powered by the inverter AND the shore power at the same time by someone other than yourself who is knowledgeable in it's design.
Every RV that has an inverter or generator that I have seen has either an automatic or manual transfer switch arrangement as a safety precaution. This can be accomplished by using a high amp double pole double throw switch. Let me know if you need more info.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 01-05-2007, 09:22 PM   #12
Safari Tim's Avatar
Images: 35
I suppose the drawing could look that way. I drew it because that's physically how it will be.
However, the wire for the plug and curbside outlets are not connected in the breaker box.
-Tim
Old 01-05-2007, 10:49 PM   #13
Phoenix , Arizona
Images: 35
I hope you are kidding about the 15 amp dvd player. You listed your inverter as 600 in the drawing and that will only produce about 5 amps. I would think a DVD player would pull 1 or 2 amps max.
OK, a candle, deck of cards and a cribbage board!.
Richard
Old 01-05-2007, 10:58 PM   #14
Safari Tim's Avatar
Images: 35
Yikes!
What I meant was 15 amps DC from the battery required to run the 150watts worth of AC devices.
...back to english class for me.... good thing I bought that School House Rock DVD
-Tim
Pingbacks are On
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
SEO by vBSEO 3.1.0
