Old 03-18-2013, 07:42 AM   #1
1977 28' Argosy 28
dexter , New York
inverter to small motor run RV??
Iam new to posting i hope this is the right place . this idea my work great or just be another dum idea of mine . I have a 4000 watt onan gen set it eats 1 gal. / hr. my idea is to run 3500/7000 watt inverter connected to a small 4hp. motor electric start with a starter generator 15amp. delco it will run about 8 hrs. on a gal of gas . I may not have ac but lights frige tv charge battery .next a inverter is 12v to 110v and a converter is 110 to 12v ?some post seems to confuse these don't they or am Iwrong again ?so a 4hp. kohler delco starter generator 15amp 12-14 volt conected to a bat. bank to a inverter 3500 watt to the moho. any thoughts would be a big help thanks .
jonesy 1 is offline   Reply With Quote
Old 03-18-2013, 08:10 AM   #2
W=EI
Wattage equals voltage times current.
3500 watts at 12 volts DC is almost 300 amps, at 100 percent efficiency.
WOW!!
Old 03-18-2013, 08:15 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You are correct in that a CONVERTER is 120 volt AC to 12 volt DC.
An INVERTER is 12 volt DC to 120 volt AC.
A 3500 watt generator will require a lot more than 4 HP to drive it.
I am not sure what you are trying to accomplish.
What is the electric motor for?
Where do you get the power to run the electric motor?
Old 03-18-2013, 02:15 PM   #4
1977 28' Argosy 28
dexter , New York
sorry I of not expressed myself well . the 4hp. motor engine is gas with a starter /gen . it puts out 15amps. to charge a bank of 2or 3 bat. then a inverter 3500 watts constant 7000 quick start or cap. draw such as a electric motor starting ac. frige saw. would the 15 amp keep up with on off draw of the moho. ??thanks
Old 03-18-2013, 04:24 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Short answer no.
15 amps@12 volts is 180 watts minus inefficiencies to an actual of about 150 watts or 1.25 amps@120 volts.
This would not be enough to run some 22" LCD TVs.
Another way to look at it is it could run a 1300 watt microwave for about 1 minute for every 2 hours the engine runs.
Now if you were talking about charging the batteries and almost exclusively using 12 volts it could work.
Old 03-18-2013, 08:17 PM   #6
1977 28' Argosy 28
dexter , New York
I think I get it the starter gen. at 15 amp. output is not enough to keep up . the starter gen. is at the flywheel end of the motor I still have a shaft with nothing on it if it had a alt. say from a truck 100-125 amp. how do I figure how much power to turn it and would it keep up any better??
Old 03-18-2013, 08:36 PM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I think you are overlooking the fact that it takes one gallon per hour to run your Onan because it requires that much energy to make 4000 watts of electricity at 120 volts. If your small motor consumes 1/8 the fuel then it's output will also be about 1/8 as much. Also every time you change from gas motor to generator/alternator to inverter you lose more. We are not considering the cost of inverters and all the other items to make this work.
At the end of the day like lunch, nothing in energy is free.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-18-2013, 08:52 PM   #8
1977 28' Argosy 28
dexter , New York
ok I have a macullouf ?? they call it a flying magnet generator it puts out 5500 watts from a 10 hp. motor it uses 2gals.in 6 hrs . . and the thing is 110 and 220 v will run important things in my house in cold weather .I talked to a guy who said Iam not even loading it that it will put out a lot more because of its type . why so much differance to the onan at 12.5 hp 4000 watts this is what is hard to under stand .
Old 03-18-2013, 08:52 PM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I am an engineer, but you have me real confused as to what you are trying to do.
Most Airstreams operate all they can using propane- fridge, water heater, stove and furnace. Battery storage, the heavier the more storage capacity, takes care of small electrical loads like lights (LED), TV, computer charging, cell phone charging, water pump, circulating fans, etc. I have two 6v golf cart batteries. I can easily go 4 days with careful use of my batteries and I have used only 25% of the battery capacity. I have a small 1,000 watt genny, but I don't even need to start it up to charge the batteries. It is really just an insurance policy, but I always bring it just in case I need it.
I suggest you look at just what your electrical loads are. Step one is always to minimize them- If my wife does not go with me, then I don't need the hair dryer and I have learned to live without the microwave and electric coffee pot. Once you identify and minimize the electrical loads then you can figure out how much battery capacity you need to meet your electrical requirements and figure out how to recharge your batteries.
Remember that new solutions have new problems. Don't try to reinvent the wheel if you don't have to.
Dan
Old 03-18-2013, 09:12 PM   #10
1977 28' Argosy 28
dexter , New York
I guess you are right ,the largest draw is the PO idea to install a house frige. and stock ac , the onan that uses 1 gal. per hr. is the problem to me . the stock frige and no ac a 4hp. 12v gen. would be great .
Old 03-19-2013, 06:36 AM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Why would you use a 12v genny? Who even makes one? I have a Honda 1000 watt genny that weighs 28 lbs and sips fuel, plus it is very quiet. I have yet to need it since I have not boondocked for more than 4 days. It will actually operate my 5k AC unit if we are camping in hot sticky weather.
When the genny is operating, all the 120v receptacles in the trailer are available and the batteries are charged up by the converter, just a hard wired sophisticated battery charger.
Dan
Old 03-19-2013, 07:27 AM   #12
1981 31' Excella II
New Market , Alabama
Your generator has some problems. 1 gallon an hr is not good. I ran my whole house on a 5500W generator when the power was out for a week and I would use about 7 gallons a day.
Get you a small efficient gas generator like a Honda and use that to power the AC to DC converter in the trailer to keep your batteries charged. Going AC to DC is pretty efficient. Going from DC to AC is not very efficient. A big 5000 W generator running 1000W load is going to use more gas than a 2000 W generator with the same load. Honda make an EU2000 that can be ganged with another EU2000 to get 4000W total output to run the AC if you want. The higher the load on an engine the more gas it uses. So if you have an unloaded engine that runs 8 hrs, it may only run 1 hour at full load. 1000W should give you plenty to charge batteries with running 2-3 hrs a day. This is assuming you run everything else on propane.
Perry
Old 03-19-2013, 08:04 AM   #13
1988 32' Excella
Get you a small efficient gas generator like a Honda and use that to power the AC to DC converter in the trailer to keep your batteries charged. Going AC to DC is pretty efficient. Going from DC to AC is not very efficient. A big 5000 W generator running 1000W load is going to use more gas than a 2000 W generator with the same load. Honda make an EU2000 (1600 watt) that can be ganged with another EU2000 to get (4000W surge) 3200W total output to run the AC if you want. The higher the load on an engine the more gas it uses. So if you have an unloaded engine that runs 8 hrs, it may only run 1 hour at full load. 1000W should give you plenty to charge batteries with running 2-3 hrs a day. This is assuming you run everything else on propane.
Perry
Fixed that for you , the EU2000 is 2000 watts surge/1600 watts continuous. The marketing department is happy their misleading advertizing is working.
Old 03-19-2013, 08:34 AM   #14
1988 32' Excella
My parents had an Airstream with the stock propane fueled 12V generator, it was rather noisy and took quite a while to charge the battery (long time is mandatory due to the way batteries need to charge). They didn't use it enough to find out how much propane it used, just on one trip and running it once in a while to make sure it worked.
So before you try it start the engine and sit next to for a few hours to see how annoying the noise is to find out if it's worth dealing with. The inverter/generators from Honda and Yamaha are designed to be quieter then most other small engines.
Also their 1000s (900 watts) and 2000s (1600 watts) are nice and compact.
How much room is your homemade rig going to take?
Unless you are going to make it built-in, which adds vibration (which also transmits noise) into the annoyance.
