We are looking to add an inverter to convert
12 volt to 110 volt power so that we can run two devices: a small drip coffee maker and a laptop computer. What size inverter should we consider? What is the best way to wire it in permanently? Alternatively, should we just plug it into one of the 3
12 volt outlets when needed? Would the factory have installed an inverter and, if so, where and what size? Is it feasible or desireable to wire the inverter within the existing electrical distribution system so that all the electrical outlets could be active via the inverter or should devices be plugged into dedicated outlets limited to the inverter circuitry?
Lots of questions. I'm not well-versed in things electrical as you can tell, but I hope these questions make sense.
I think we have plenty of battery capacity. We have the solar collector that feeds two glassmat batteries.
