Old 01-26-2019, 09:59 AM   #1
murrieta , California
inverter outlets 2 or 3 prong
Hi, I need to run my cpap off of battery power while boondocking and it has a 3 prong cord (ground included). I can't remember and the airstream is in storage but i believe the interter outlets are only 2 prong. has anyone changed these out for a 3 prong outlet?
Alexstjo26 is offline   Reply With Quote
Old 01-26-2019, 10:00 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You don't identify your coach. What year etc.
Old 01-26-2019, 10:28 AM   #3
2017 27' International
Lake Havasu City , Arizona
12 VDC power adapters are available for most CPAPs. You'll find this uses less power than the large inverter Airstream installs. If you can't get a 12 VDC adapter for your particular CPAP model, I suggest buying a small inverter that is sized for your unit's power needs. Again, it will be less power-hungry than running the large Airstream inverter.
Paprika is offline   Reply With Quote
Replacing 2 prong electrical outlets. ttbikes Electrical - Systems, Generators, Batteries & Solar 16 04-08-2018 08:48 AM
Vintage trailer with two prong outlets BambiTex Batteries, Univolts, Converters & Inverters 6 03-11-2015 02:08 PM
Inverter outlets not working FinnSwede Batteries, Univolts, Converters & Inverters 10 11-16-2011 03:14 PM
Bargman #99 Tailight refit 6-prong to 7-prong silverkeeper 1960 Safari 6 03-05-2011 10:01 AM
Installing Inverter to run all AC outlets in Airstream Interstate Aahj Batteries, Univolts, Converters & Inverters 6 05-17-2010 07:22 PM
