Old 10-28-2019, 02:36 PM   #1
2017 20' Flying Cloud
Georgetown , Texas
Inverter not attached to floor
I had the bed out and wood panel removed just to inspect wiring. Noticed the Inverter module is not tied down in any way it can move in all 4 directions maybe a half inch and nothing to restrain it from bouncing up and down. That can't be good for the wiring connections or the inverter.
If you agree, you might want to check that in your AS.
Going to add screws to attach mounting feet to floor.
SYC2Vette is offline   Reply With Quote
Old 10-28-2019, 03:47 PM   #2
2019 25' International
Providence , Rhode Island
It will be interesting to hear peoples thoughts on this........as AS as usual type responses.
I noticed this also in my 2019 and thought to myself......"you got to be kidding".....I have full plans to do as you mention and shore it up and dress the wiring accordingly.......I can see they need to put stuff together fast.....but leaving it to just "flop around" like that just doesn't cut it as an answer......IMO.
kittmaster is offline   Reply With Quote
Inverter outlets not working attached to shore power kkdesigns Batteries, Univolts, Converters & Inverters 39 02-03-2019 09:16 AM
Lift-Off: Leave C-Channel Attached to Shell vs Sub Floor? LifeIsRiveting General Repair Forum 10 01-23-2016 02:21 PM
Walls attached to floating laminate floor? boo_n_sue Floor Finishes 27 07-09-2011 09:36 PM
'62 Bambi - window operator not attached kamo Windows & Screens 3 08-16-2006 06:34 PM
