04-08-2015, 05:50 AM
#41
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
If I had installed the factory inverter and solar system in our Classic, all those components would have been removed and trashed and the wiring not used when we installed the large system. It would be possible to acquire at least two and perhaps three times the solar wattage and appropriate equipment with properly sized wiring for the charges of those two factory options. Plus the owner gets to determine where the control head will be located.
On our queen bed 25FB, the dealer installed the Zamp solar controller right beside my wife's face in the cabinet beside the bed. As soon as the sun came up, it started blinking and would awaken her. They could have mounted it two feet higher at eye level when standing and it would have been less intrusive.
Perhaps improper dealer installation caused the 155 watt solar panel on our 25FB to not work properly, but in full clear sky daylight, it would not bring the standard factory batteries to a full charge (lucky to see 90%) after the furnace ran during the night and brought the batteries down to 50% per the Zamp control head. So we had to run one of the 2000 watt Honda generators to top the battery up. The factory installed 600 watt inverter (changed to a 1,000 watt model later in the 2013 model year) would not even run our toaster, so the generator had to be run for most anything that drew more than a few watts of power.
The devil is in the details as to whether the installation works properly or not. Many Airstream dealers totally lack the knowledge to properly install a really sophisticated solar system and the customer ends up disappointed in the performance, but lacks the knowledge to ascertain it was due to installation errors.
04-09-2015, 12:01 AM
#42
2013 27' FB International
El Dorado Hills
After installing one and using it for awhile I've decided the importance of an inverter is overrated. The battery system in any Airstream (excepting those radically modified) cannot sustainably power the air conditioner, the microwave, or a coffee maker or toaster etc.
So this leaves the TV, and cell phone / laptop recharging duties. With a little rewiring effort the TV could even probably be wired to power off 12 volts supply. Any car charger can recharge cell phones and laptops. In my case, assuming the above, all I really need the inverter is to power the blender and vacuum. Both are just luxuries.
04-09-2015, 01:05 AM
#43
2016 30' International
Scottsdale
Lou... if you ordered a new AS today, with no factory solar or inverter options... would you drive to Texas to remedy the situation? Or could it be well-remedied here in AZ?
04-11-2015, 09:52 AM
#44
2014 31' Classic
Apache Junction
I would do what I did before. I went to a recommended AM Solar system installer who knew what they were doing. This was a too large and expensive of a project for any outfit without large system installation experience.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Inverter sizing for factory convection/microwave oven?
myoung |
Electrical - Systems, Generators, Batteries & Solar |
13 |
09-08-2018 12:57 PM |
Is this a factory installed solar panel ? I think it's factory installed and ...
JacobMerridy |
1 |
01-14-2017 10:23 AM |
New Airstream - Window Awnings - factory vs. aftermarket?
DHart |
Windows, Doors, Locks & Vents |
4 |
04-05-2015 01:35 AM |
Aftermarket inverter install International 27 FB
LAWBC |
Batteries, Univolts, Converters & Inverters |
20 |
01-29-2013 08:24 AM |
Alternatives to Factory Converter & Inverter
shovelbum |
17 |
04-05-2008 12:14 AM |
