Old 02-21-2016, 02:17 PM   #1
1978 31' Excella 500
Portland , Oregon
Question Interior outlets dead
I'm new to Airstream Forum. Hopefully someone can help me with my problem. I have a 1978 Excella 500. Last summer I turned on my air conditioner. After running for a few minutes it stopped running. All my interior outlets died too. I used the trailer through the summer staying powered up by my solar panel. I dry camp most of the time. I am attempting to remedy my 120 volt system. I've used my test meter to check for power. I show 120 volts of power coming in the trailer, at the breaker panel, and all the plugs. Ground to hot and ground to neutral. The polarity light is on. I still cannot get anything 120 to work in the outlets, lamps, space heaters, vacuums. NOTHING!!! Very frustrating. Any help would be greatly appreciated.
craiglkirk is offline   Reply With Quote
Old 02-21-2016, 02:53 PM   #2
2005 31' Classic
Pleasant Plains , Illinois
You might try another test meter. If the one you're using shows power at the outlets yet nothing you plug in works, I would be suspicious of it.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
WGreg is offline   Reply With Quote
Old 02-21-2016, 04:08 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ground to neutral shows power!!???
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-21-2016, 04:28 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The reverse polarity light should NOT be lit. This is an indication of the hot leg and neutral being reversed. It could be at the shore power outlet or in the shore power cable.
You should read 120 volts between the hot leg and the neutral. You should also read 120 volts between the hot leg and ground.
You should NOT read any voltage between the neutral and ground.
When properly wired the reverse polarity light is connected between neutral and ground and should not be lit when the system is working properly.
You could also have an open neutral. Where the 120 volts will "stand" on the neutral side because it has no return path.
I would check for reversed hot leg and neutral first. If that is correct. Then look for an open neutral.
Dead wall outlets mgap Batteries, Univolts, Converters & Inverters 19 06-26-2013 08:40 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
350LE Motorhome - 110 outlets dead Delaware Electrical - Systems, Generators, Batteries & Solar 12 10-05-2009 05:52 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
All 120 outlets are dead LI Pets Electrical - Systems, Generators, Batteries & Solar 4 09-10-2006 08:02 PM
