Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-23-2007, 07:34 PM   #1
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
interior lites/LED bulbs
when I put in an 1156 LED replacement bulb in my interior wall lite of my 65 caravel , it didn't work. the old auto-type bulb worked in there,so.... how do you find out if it's a grounding issue if both wires disappear into the wall? and how would you fix it?? joe in MN
joqin is offline   Reply With Quote
Old 01-23-2007, 07:37 PM   #2
TIMEMACHINE's Avatar
Huntington Beach , California
Sounds like a bad LED lamp to me, unless of course if the socket doesnt match the lamp base. Just guessing.
TIMEMACHINE is offline   Reply With Quote
Old 01-23-2007, 07:47 PM   #3
Jacob D.'s Avatar
1964 26' Overlander
Alameda , California
The polarity in the fitting could be reversed. Use a multimeter to test if the center pin in the socket is +12V relative to the outer shield. If it's -12V, reverse the wires to the fixture. LED bulbs generally require correct polarity in the socket although some have a rectifier built in so they can also be used on negative-ground circuits.
Without the multimeter you can just switch the wires to the fixture and see if it works.
Jacob D. is offline   Reply With Quote
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
Bulbs - Tail and Clearance Zed2 Lights - Interior & Exterior 3 07-13-2005 11:53 AM
oven bulbs? Chas Stoves, Ovens & Microwaves 4 07-21-2003 07:54 AM
taillight bulbs davidz71 Lights - Interior & Exterior 4 02-14-2003 08:59 AM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 02:08 PM
