Old 06-26-2005, 07:38 PM   #1
interior lights
I have a 74 land yacht the light over the sink work but the one next in line & the one one over the bunk don't any ideas?
towguy is offline   Reply With Quote
Old 06-26-2005, 10:00 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Welcome to the forums. Let me be the first to ask the obvious question ... Have you checked the bulbs? Anyone else have ideas?
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-27-2005, 06:26 AM   #3
interior lights
yes I have,I can run a jumper wire from the working light over & get the other 2 working but the wire gets hot & the lights are dim.
Old 06-27-2005, 11:21 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Short?
How do the fuses look? There is a set of fuses that work the lights, usually inside the cover of the Univolt. If one of them is blown, it is possible you have a short on that line, that is why the loghts are dim, and don't work independently. It would also be why the fed wire you are using gets hot.
Old 06-27-2005, 01:03 PM   #5
Uberlanders's Avatar
1968 26' Overlander
Wenatchee WA , Cape Cod
Some of ours did not work correctly either. Years of dust, water leaks, etc had corroded some of the switches. We took the switch off of a working one to replace one that wasn't working. That was the trick. Then we got some new switches through Inland RV.
Jim & Kathleen
1968 Overlander - WBCCI #5793
Uberlanders is offline   Reply With Quote
