Old 08-13-2006, 12:58 PM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Interior Lighting
The 12 volt interior, overhead lighting in Lucy is quite glaring. Has anyone ever used a rheostat (dimmer) switch or is there something else that someone has done to dim or shade these bright lights?
SuEllyn & Brian McCabe
Old 08-13-2006, 01:45 PM   #2
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
Hi Moosetags,
If you're talking about the lights over the dinette and pull-out sofa/bed, we removed those lights and put in mini-flourescent ones, as well as in the bathroom..We still kept all the mini dual lights on the dinette and sofa/bedb wall..those are still very bright for sure
codybear is offline   Reply With Quote
Old 08-13-2006, 04:33 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If those are 12v incandescent or halogen lights, there is no reason not to install a rheostat or potentiometer to adjust light levels. A good 12v potentiometer is available from Radio Shack for less than $10. They are easy to wire, I have done several. If you have flourescent lighting, it doesn't respond well to dimmer switches.
Old 08-13-2006, 07:26 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You can use smaller wattage halogens, if you want it dimmer without wasting electricity with dimmers. Led's make nice alterantives with less light and alot less wattage wasted.
Old 08-14-2006, 07:10 AM   #5
moosetags's Avatar
Tips
Thanks for the lighting tips.
Old 08-14-2006, 08:13 AM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Dim it
These work well and do not waste energy, because they limit the current electronically, not by a resistor that gets hot.
http://cgi.ebay.com/ebaymotors/12V-L...QQcmdZViewItem
I bought 2 of them for my 63.
Uwe
www.area63productions.com
Old 08-14-2006, 08:44 AM   #7
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
A good source for 12 V fluorescent and halogen lights is RV Salvage in Elkhorn, IN. We replaced the bedroom and aisle lights in Chummy from there. If you do not see it on the web page call them.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-14-2006, 09:38 AM   #8
myoung's Avatar
Nipomo , California
Images: 24
In-line or replacement?
Uwe,
Did you put the dimmers in-line with the existing light circuitry or did you use the dimmer as a substitute for the existing light switch? Hope this question is clear.
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion" (coming soon)
BMW X3 xDrive 28D
myoung is offline   Reply With Quote
Old 08-14-2006, 06:52 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Originally Posted by myoung
Uwe,
The dimmers can go in line, or replace the light switch. There is a click at the end of rotation that turns the lights off. Each can handle about 60W safely. No need to use the ugly face plate and know either, it can attach by means of the potentiometer shaft, and accept a nicer knob.
Uwe
Old 08-16-2006, 10:12 AM   #10
moosetags's Avatar
It is the three ceiling lights over the dinette table that we would like to control. These are not on a central switch. Each one is switched at the light separately. The potentiometer seems like the best and cheapest solutiion or am I missing something?
