Old 03-25-2006, 10:41 PM   #1
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Interior 12 Volt Lighting - Juno Trak 12
This past chat night, several of us were discussing interior lighting. I mentioned the set up I have in our Trade Wind. Its a product called Trak 12 by Juno. They offer anumber of different fixtures and I especially liked the recepticle for plugging in different lights. In fact, we found a lighting store going out of business and we bought their Juno display. This gave us about 7 or 8 of these recepticles and a few different styles of 12 volt DC halogen lights. This was about 4 years ago and they have alot more styles of fixtures that fit in these recepticles now. The lights insert into a slot and turn 90 degrees and lock in place. Here are a few pictures of the different lights we have. The pictures aren't a good representation of these lights and the recepticle and the flood light were difficult to photograph.
I'll take a couple more shots tomorrow during the daylight so you can see the fixtures.
FF
ID:	19841   Click image for larger version
ID:	19844   Click image for larger version
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-26-2006, 09:05 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Brad,
AWESOME IDEA!!! Thanks for sharing it . It opens up a whole new world of lighting effects for the little blimps that we love so much. And Karma to you too!!
Old 03-26-2006, 02:15 PM   #3
early's Avatar
Hey Brad great lights. Do they have a website?
Thanks Dawn
early is offline   Reply With Quote
Old 03-26-2006, 02:21 PM   #4
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here's a site with pictures of the Juno Trac 12 line.
http://www.lightology.com/index.cfm/...dept-Trac%2012
Now that I've posted this and looked through the website, I'm going to order the midnight blue glass for the hanging light. It's just too cool looking.
FF
Old 03-26-2006, 03:22 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Excellent idea! This can solve the "light over the dinette" problem that has been on my mind. Didi likes a bright table, and with this I could put a light right above it.
Uwe
www.area63productions.com
Old 04-06-2006, 06:07 PM   #6
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
On Order
Just couldn't stand it. Ordered the sort cone glass globe in cobalt with the silver hanging pennant cord. Went to a lighting store today to look at the real thing and their prices were $10 to $12 higher on each piece plus tax than from Lightology.com and shipping was free. Like I said, just couldn't stand it. Hurry up USPS.
FF
Old 04-06-2006, 07:10 PM   #7
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
o.k. so I'm not real swift when it comes to electrical....as these are 12v lights, do you really need the transformer? The transformer is used to convert 120vac to 12vdc right? Can you just hook these up to the 12v system in the Airstream and go? I would love to have a nice hot light above my customer viewing station to pop the colors of my shirts!!
I've got 120v on all the time but my indirect lights are all 12v floresent and that would be a great place to tie into.
Your thoughts gang?
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 04-06-2006, 07:22 PM   #8
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
You can certainly tie into the 12 volt line for these low voltage lights. My concern would be that these lights are halogen and draw alot of juice. I would put them on a seperate circuit rather than tie into one with 12 volt flourescent lighting. You are correct, there is no reason for the transformer wiht these 12 volt direct current lights.
FF
Old 04-06-2006, 09:10 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
FF
Hey Brad,
It's not the halogen that draws the juice, it's the wattage of the lamp.
A 10W halogen lamp draws similar juice as a 10W tailight bulb. It's just brighter with halogen, and usually a different light color.
The little cone shaped lamps that work with the Juno lamps are available in low wattage if you want to get a few for boon docking.
Uwe
Old 04-07-2006, 07:13 AM   #10
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Thanks for the info Uwe. Guess that makes sense. So where can I get these lower wattage lamps to fit the existing Juno fixtures? Are they a common item available at Lowe's or Home Depot? I'm putting a monoport above each bed and want less bright light for reading.
FF
Old 04-07-2006, 08:28 AM   #11
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
FF
Brad,
each of these lamps has a specific group part number. I am not sure which is the ones your lamps use. I would simply google this pat number and find a supplier.
e.g. , Lowes wold carry only 50W and 35W of the little lamps that have the built in reflector, and the 2 pin connector. ( Sorry, I forgot the part number) I found 20W versions of these on the internet.
The small 2-pin bulb without the reflector is even available in a 5W version. Another option is to install a dimmer for the lamps that are naturally too bright for certain applications. I found 12V energy saving ( not energy burning) dimmers on e-bay for less than $ 30.00 each. I will put them in my Overlander for the wall lamps, and for the main run of lights in the ceiling.
btw, a great and economical source of the halogen lamps is Ikea.
Uwe
Old 04-07-2006, 08:30 AM   #12
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Here's a start:
http://www.swego.com/12_volt_bulbs.htm
G4 for the 2-pin, and MR16 for the reflector type lamps.
An these guys have them in 20W, both flood and spot:
http://www.lightbulbdirect.com/Merch...gory_Code=MR16
Uwe
Old 04-07-2006, 08:49 AM   #13
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Hey, nice Tivoli radio. We have several and one (the travel, battery rechargable version) always goes camping with us. Your coach is done up with style. If I ever get that gutted 50-68 gutted Safari/Flying Cloud for cheap some day, this kind of think is exactly what I would do.
John
AYRSTRM2 is offline   Reply With Quote
Old 04-07-2006, 09:09 AM   #14
AirConditioner's Avatar
Halogen vs LEDs
Check out the recent progress made on high-output, very low current draw Light Emitting Diodes (LEDs) from this vendor. http://www.ledtronics.com/
They and other LED vendors have direct repalcement for the halogen bulbs used in most existing fixtures, and you will be amazed at the very similar light output.
I'm using a few of these in my 72 Overlander as a test, and will replace all my lighting within the month. I went from about 10 amps draw with all lights on to less than 1.5 amps; less heat (hardly any), and 20 year life - vibration proof.
These also work in our outside marker, tail and brake lamps, as well as the side "scare" light.
AirConditioner is offline   Reply With Quote
12 volt
12 volt TV? john hd On The Road... 52 07-02-2008 02:16 PM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
Gas Lighting kzener40 General Interior Topics 4 11-06-2002 12:43 PM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 10:13 AM
Lighting problems ramoore53 Electrical - Systems, Generators, Batteries & Solar 1 05-08-2002 10:02 AM
