Old 09-23-2006, 05:19 PM   #1
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Intellipower wiring
What gauge stranded copper wires should be used for
the +/- lines from Intellipower 9100 direct to the
battery +/- ?
Safari64 is offline   Reply With Quote
Old 09-23-2006, 05:44 PM   #2
Images: 59
#6.
Old 09-23-2006, 05:57 PM   #3
Safari64's Avatar
1964 22' Safari
Thanks, can I run them tied together?
Old 09-23-2006, 05:59 PM   #4
Safari64's Avatar
1964 22' Safari
What
Old 09-23-2006, 06:00 PM   #5
Safari64's Avatar
1964 22' Safari
What gauge wire for the Intellipower to chassis ground?
Old 09-23-2006, 06:50 PM   #6
Images: 59
I think #12 from the Intellipower chassis ground lug to the airstream body ground. The ground lug is 7/32", I don't think much more than a #10 would fit in the hole.
Old 09-23-2006, 11:06 PM   #7
Safari64's Avatar
1964 22' Safari
Thanks for the help
Old 09-23-2006, 11:32 PM   #8
New Borockton , Alabama
Images: 21
Safari,
At least 8 AWG rated for 90 degrees Celsius and you are fine as far as safety issues go. Bigger is better and I think you will see better performance in the automatic mode if you use bigger wire.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
