Old 06-08-2006, 04:00 PM   #15
Images: 59
Originally Posted by Safari64
If the "Wizard Orb" is going to light up my life with green glow even on the darkest nights..that's a good reason to get the 9260 internal charge wizard.
Safari64
I suppose you could make a cape for the green orb out of a piece of black electrical tape.
On the other hand, I know that you can order two different charge wizards for the 9100, depending on whether you have wet cells or AGM batteries. I don't know if the 9200 has a selector switch.
Also, having the push button on the charge wizard lets you manually over-ride the charge program. This is a good thing if you know what you are doing. It could be a bad thing if you don't.
Old 09-05-2006, 03:56 PM   #16
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Do these Intellipower units fit in the same box that the Univolt resides in a 1979 Vintage 31' International? How much disassembly of the Goucho is required for the swap?
wacnstac is offline   Reply With Quote
Intellipower in and tested… Buttercup Electrical - Systems, Generators, Batteries & Solar 16 06-27-2005 04:35 PM
Intellipower Ground(s) Over59 Electrical - Systems, Generators, Batteries & Solar 15 06-16-2005 10:22 PM
Intellipower wiring? 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 16 04-23-2005 01:06 PM
Intelli Power 9100 help Jimbo Electrical - Systems, Generators, Batteries & Solar 2 06-28-2004 07:54 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 12:08 PM
