Old 07-21-2006, 06:22 AM   #1
1985 31' Limited
Ashland , Nebraska
Intelipower charge wizard?
Can you use this with a univolt converter to adjust your charge rate of your batteries? Instead of buying a new converter? It monitors you battery needs and adjust the charge rate at three different rates.
jlsmits is offline   Reply With Quote
Old 07-21-2006, 06:36 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
No, the Charge Wizard is made for the 9100 series Intellichargers. I plugs into a port on the 9100 series. There is no port to plug it into on any other make or model converter.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 11:57 PM
internal charge wizard or external dragonnfly Electrical - Systems, Generators, Batteries & Solar 8 07-12-2006 03:18 PM
Charge Wizard - Help! dmreilly10000 Electrical - Systems, Generators, Batteries & Solar 6 11-15-2002 04:37 PM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 04:31 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 06:49 AM
