Old 06-09-2008, 10:49 PM   #1
1975 31' Sovereign
Pensacola , Florida
Inteli power or Xantrex
Hello everyone. I was curious what everyone would suggest, Intelipower 70 amp or Xantrex true charge 60 amp for my 1975 31' ...thanks for any advice
RandyG is offline   Reply With Quote
Old 06-10-2008, 12:05 AM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
I replaced the Univolt with the Xantrex unit for our 28 footer. We have only the two Group 27 batteries, so I felt the 40 amp unit would do.
If you're trying to run lots of 12 volt stuff when plugged into shore power, the larger amp rating might be a better choice.
I've only used it twice since installing it, but it's quietly doing it job for us, and the batteries are 'floating' properly.
Got mine from Best Converter.
Ray & Pat; Morada, CA
Old 06-10-2008, 07:43 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
RandyG,
Don't forget the several other options available to you like the Parallax Paramode with temperature compensation and the WFCO units. Your best bet would be to give Randy a call at Best Converter.... BestConverter - Converters, Inverters, Electrical Supplies, Electronics.
charger, electrical, univolt, intelli-power
Just received my new Inteli Power 9100 delquattro Electrical - Systems, Generators, Batteries & Solar 3 04-12-2005 07:20 PM
Inteli-Power 30/40/50/60????? GT1963 Electrical - Systems, Generators, Batteries & Solar 1 02-05-2005 11:40 AM
Univolt +/- Inteli-Power = ? krowsea Electrical - Systems, Generators, Batteries & Solar 4 11-14-2004 10:24 AM
Inteli Power 9100 Bryanhu Electrical - Systems, Generators, Batteries & Solar 4 04-12-2004 04:27 AM
Univolt replacement with Inteli Power Craig Electrical - Systems, Generators, Batteries & Solar 6 05-04-2003 11:37 AM
