Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-29-2015, 12:09 PM   #1
Osogofind
1975 25' Tradewind
Installing inverter and battery backup inside
Hello,
I'm weighing ( literally) my options of putting in battery backup sealed AGM and Kyocera inverter inside my airstream. It would be in the rear under the bed ( remodeled 75 land yacht- the bedroom is in the rear)...I have a good 2'clearance and a ton of dead space.
The weight would be about 150 lb extra with batts and inverter.
Is this too much?
My alternative is to build a portable battery box and inverter to plug the main power into.
Bwilson11 is offline   Reply With Quote
Old 04-01-2015, 09:36 PM   #2
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
The important thing to remember when adding weight to your AS is to ensure it does not negatively impact your tongue weight. Depending on where you choose to locate this extra weight (too far forward = too much weight on vehicle, too far back = not enough weight on the hitch) it should be fine. Put the extra weight over the axels and you don't have to worry about tongue weight.
trekerboy is offline   Reply With Quote
Installing an inverter in a Bambi... Any advice? R2DTube Batteries, Univolts, Converters & Inverters 19 05-17-2013 06:01 PM
Installing Inverter to run all AC outlets in Airstream Interstate Aahj Batteries, Univolts, Converters & Inverters 6 05-17-2010 07:22 PM
Inverter Use and Battery Level TouringDan Batteries, Univolts, Converters & Inverters 28 05-13-2010 09:09 PM
installing a Xantrex inverter? boondockdad Batteries, Univolts, Converters & Inverters 12 12-05-2007 12:25 PM
Installing an Inverter Krazykraut General Motorhome Topics 4 12-08-2002 11:22 AM
