Old 04-26-2015, 04:43 PM   #1
1990 32' Excella
jonesboro , Arkansas
installing intellipower
I am installing a 9130 in my 1990 32 excella . In removing my old convertor I found a large red wire+, a large white wire-, and a smaller black wire. The smaller black wire is what I am trying to figure out. Does anyone know what the smaller wire goes to.
joel is offline   Reply With Quote
Old 04-26-2015, 07:16 PM   #2
1974 Argosy 20
Kooskia , Idaho
It most likely is the wire to the Power On light in the control center. There is no easy way to make it do what it did with the original Univolt when you put a new converter/charger in. It was a special tap in the original humming box. Most just leave it disconnected from anything and if they want a power on light, use a little neon nightlight plugged into a 120 volt outlet in the trailer.
Old 04-28-2015, 08:12 AM   #3
1990 32' Excella
Just checked my post. Thanks.
Installing a new intellipower converter 45 amps toastie Electrical - Systems, Generators, Batteries & Solar 18 06-01-2013 03:54 PM
Installing an Intellipower 9200 29348 Batteries, Univolts, Converters & Inverters 16 06-17-2007 09:48 PM
Intellipower Ground(s) Over59 Electrical - Systems, Generators, Batteries & Solar 15 06-16-2005 09:22 PM
Intellipower wiring? 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 16 04-23-2005 12:06 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 11:08 AM
