Old 07-20-2009, 10:25 PM   #1
2009 25' FB International
las vegas , Nevada
Installing 30 Amp outlet at home??
Hey, AS newbie here.
since I live in Hot Vegas, I was thinking that it would be nice to plug in the AC while I do some work in my new 09 AS 25' international, but I"m assuming that I would need a 30 amp outlet, and I don't seem to have such outlet anywhere in the house.
Has anyone had 30 amp outlet installed in their garage/house?? How much does something like that cost?? I do have a secondary breaker box with a dozen or so 10-20 amp switches in the garage and was thinking an electrician "could" install an outlet next to it possibly??
lvcat2004 is offline   Reply With Quote
Old 07-20-2009, 10:55 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings lvcat2004!
I have had a 30-AMP electrical outlet added at each of my homes since I first started RVing in 1980. The outlet with weatherproof outlet box was under $40.00 for my most recent installation (it seems like it is easiest to find these two items at an RV accessory store). My electrician was already on-site to install electrical service for my garage so there wasn't a trip charge for this job, the wire -- breaker -- and labor came to $175.00. Be sure that your electrician understands that this outlet is 30-AMP 120-Volt rather than 30-AMP 220-Volt -- I had one licensed electrician hook my outlet up just like it was for a dryer, and when he asked me to plug my Minuet into the outlet I inquired as to the voltage of the outlet and his response was "220-Volt" needless to say, I referred him to the service order where 120-Volt was underlined (20 minutes later he had the mistake corrected).
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-20-2009, 11:00 PM   #3
las vegas , Nevada
thanks again Kevin!! I'm sure I'll have more Q's....
Old 07-20-2009, 11:19 PM   #4
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
If you just want to run the AC, a 20 amp will do.
But if getting a electrican anyway, go for the 30.
It comes in handy for welders and such.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 07-21-2009, 07:23 AM   #5
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
http://www.airforums.com/forums/f427...-ac-53972.html
RLS is offline   Reply With Quote
Old 07-21-2009, 07:24 AM   #6
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Go ahead and get 50amps, then just use a plug adapter.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 07-21-2009, 08:10 AM   #7
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
make sure to get the correct AWG wire for the distance you require. Voltage Drop Calculator
elbundi is offline   Reply With Quote
Old 07-21-2009, 09:09 AM   #8
Chasmorgan's Avatar
1999 23' Safari
Just had this done. Midwest Electric 5X7 Power Outlet $25.00 plus tax at Lowes, Electrician supplied labor, breaker and installation for $100. Works great!
Chasmorgan is offline   Reply With Quote
Old 07-22-2009, 09:41 AM   #9
FischerRA's Avatar
1990 25' Excella
1995 34' Limited
Crestwood , Kentucky
I would not use a 20 amp. Anything less than 30 could ruin your A/C. Have a qualified electrician install a 30 amp or even better a 50 amp near where you park your trailer. I had mine installed with a several years ago on the outside of my workshop and it is very handy and I just leave my trailer plugged in. Cost was around $250 and well worth the price.
FischerRA is offline   Reply With Quote
Old 07-22-2009, 10:52 AM   #10
dstalzer's Avatar
2005 25' Classic
I have used the 20 amp outlet to only run the A/C. If anything else is running on that circuit, the breaker will trip. I am planning on adding a dedicated 30 amp outlet in my garage exclusively to be able to run everything in my AS.
Dennis
dstalzer is offline   Reply With Quote
Old 07-22-2009, 03:04 PM   #11
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
actually.. no. if feeding 20 amps to the trailer, and using that feed only to run the AC, it cannot hurt your AC at all, your AC is on a 15amp circuit, so you are feeding more amps then the circuit can forward to the AC.
Now, if you are feeding 20 amps, AC running, and you do something else in the trailer to "steal" the amps from the AC circuit, say nuke a cup of cocoa, or switch your fridge to elec, then you can have problems.
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 07-22-2009, 03:11 PM   #12
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Its best to get a dedicated outlet. If you use an existing 20amp outlet in the garage there may be other things using the same breaker like a freezer and that would be bad news for the AC.
Garry
wiring a new 30 amp outlet gparker Electrical - Systems, Generators, Batteries & Solar 22 03-25-2010 08:07 PM
Need advice on 30 amp outlet box RLS Electrical - Systems, Generators, Batteries & Solar 12 05-29-2009 09:56 AM
Installing 12V Home Lighting spitfyr Lights - Interior & Exterior 4 10-17-2007 12:14 AM
Installing an outdoor outlet Chuck Electrical - Systems, Generators, Batteries & Solar 14 11-10-2004 10:59 PM
30 amp outlet john hd Electrical - Systems, Generators, Batteries & Solar 20 02-26-2003 01:54 PM
