Old 04-30-2016, 09:12 AM   #1
wareaglewalt's Avatar
2017 25' Flying Cloud
Bushnell , Florida
Installing 2 6-volt batteries
There is a shallow plastic tray under the Group 24 batteries I'm taking out. My new T-105 6-volt batteries won't quite fit in the tray. Is the tray absolutely necessary and/or is it bad to have the new batteries sitting directly on the metal bottom of the battery box?
wareaglewalt is offline   Reply With Quote
Old 04-30-2016, 09:16 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Lose the tray. It is not needed.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 04-30-2016, 09:19 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Some people add a two or three inch extension to the top of the box.
This is mine, made with 2 inch aluminum C-channel screwed to the box. Plenty of room for the taller batteries with a bit of extra room. I removed the tray and cut a piece of thin rubber mat that I had to fit. The plug is for 12 volt accesories or plugging in my Solar suitcase panels.
MICHAEL
Old 05-03-2016, 02:01 PM   #4
2005 22' International CCD
Cambria , California
New T105 Batteries
For those of you looking at 6 volt T105, Trojan now makes a new model called the T105RE. It has "Smart Carbon Technology" which basically adds some carbon panels inside the battery. They have a larger terminal which add about 1/2 inch to the top.
Normal T105 warranty is one year unlimited and one year prorated. T105RE is 2 years unlimited and 5 years prorated and is expected to last 10 years with excellent performance.
The new battery is more expensive but should pay for itself and more.
Ziggy2 is offline   Reply With Quote
Old 05-04-2016, 10:42 AM   #5
2012 25' FB Flying Cloud
Grand Rapids , Michigan
Quick question: Will these 6 volts get along with the PD4655 charger?
Jwestman is offline   Reply With Quote
Old 05-04-2016, 11:09 AM   #6
2015 23' FB Flying Cloud
Redmond , Washington
Yes, I recently installed a PD4655 and am considering 6V batteries. Are these compatible?
WestieHouse is offline   Reply With Quote
Old 05-04-2016, 11:38 AM   #7
2013 Int. Sig 23D
Rrroberts40's Avatar
2013 23' International
Des Moines , Washington
Yes, you wire the 6v batteries in series instead a parallel it "sees" them as a 12 v battery...My PD4655 works GREAT with the Lead/acid 6v pair.
Russ
Rrroberts40 is offline   Reply With Quote
Old 05-04-2016, 11:40 AM   #8
2010 27' FB International
La Crescent , Minnesota
Same Question? Only a PD4645.
Jay
mjayjensen is offline   Reply With Quote
Old 05-04-2016, 11:59 AM   #9
2016 23' International
Salem , Oregon
I replaced my controller with the PD4655 but the batteries were already shot by the previous owner in only 4 or 5 months. Can't make up my mind as to adding solar as a lot of my camping will be in the forests. Think maybee a Zamp 200 watt panel would be a better option as trailer in shade and solar in sun. No holes to drill and installation expense of fixed panels, however a mix of both may be in the future.
Would be interested to see hat Rrroberts40 is doing as his is similar to my trailer.
Dave
NoResults is offline   Reply With Quote
Old 05-04-2016, 12:09 PM   #10
lewster's Avatar
Dave
NO HOLES if you install the panels 'properly'!!!
Lew Farber
541-490-6357
Old 05-04-2016, 01:34 PM   #11
PKI
PKI's Avatar
Walnut Creek , California
Used to be a belief that the surface of a battery would conduct low level current to any ground source. Hence the advice to not store a battery directly on concrete, which can absorb moisture. A tray provides insulation from such current leakage, if you believe such is possible. However, I always believed that the primary purpose of a tray was to capture any spillage of acid.
Is it a terrible mistake to ditch the tray.? Likely not. A new battery box is not a significant expenditure. Is it a good idea to install a tray? Likely it is. However, a good coat of acid resistant paint might be any acceptable alternative that is less problematic to implement.
Thanks for posting the issue. I had not given it much thought. Pat
PKI is online now   Reply With Quote
Old 05-04-2016, 04:07 PM   #12
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
If the tray is removed, will the 2 6v batteries fit? ...or is box modification, as shown in the photo, necessary with the T105 Trojan batteries?
Glenn T is offline   Reply With Quote
Old 05-04-2016, 04:14 PM   #13
Lets travel's Avatar
2014 30' Classic
Fayetteville , North Carolina
Please post
Lew, can you post some schematics on how to wire two 6 volt batteries in replacement for the Group 27 batteries.
Lew Farber
541-490-6357
Lets travel is offline   Reply With Quote
Old 05-04-2016, 04:21 PM   #14
AWCHIEF's Avatar
Images: 33
The Trojans are almost Two inches taller. They would not fit in my box without the extension.
MICHAEL
Two 6 volt batteries replacing one 12 volt TY PECK Electrical - Systems, Generators, Batteries & Solar 2 11-12-2015 12:22 PM
installing 4 6 volt batteries on Safari 27 FB The Driver Electrical - Systems, Generators, Batteries & Solar 8 05-12-2012 07:08 AM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
