Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-06-2007, 01:59 PM   #1
beginner5
Profile:  1965 26' Overlander
winnipeg , manitoba
Install new umbilical cord
am working at restoring a 65 overlander. I would like to replace the umbilical cord and the brake breakaway switch.
they run from the very front of the a frame to the opening in the belly pan where the circuit breaker is positioned. they run inside the the a frame thru a tight hole at the front and come out thru a small hole in the a frame accessed through the belly pan hole. my problem is they are so tight going thru each of these holes that they can't be budged no matter how hard I push or pull. there is no access to the frame from above inside the trailer so I'm guessing u somehow have to find a way to pull these 2 wires thru. Does anyone know of a methodology for doing this or am I missing another way to access the wires
Glenn
beginner5 is offline   Reply With Quote
Old 07-06-2007, 02:29 PM   #2
bobkelly
bobkelly's Avatar
Profile:  2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Welcome to the forums! I can't help with this one, but someone will come along soon who knows how.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 07-06-2007, 02:51 PM   #3
beginner5
winnipeg , manitoba
Forum Gods
Thanks Bob good to be here
Glad I found this site-
My family refers to this site as "The Airstream forum Gods"
since there always seems to be an answer no matter how tough the question. I wonder how many old airstreams would be sitting idle in the back yard without this site
Old 07-06-2007, 02:59 PM   #4
urbanfood
urbanfood's Avatar
Profile:  1956 22' Flying Cloud
Venice , California
you mean like this one
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 07-06-2007, 06:23 PM   #5
CharlieE
Profile:  1990 34' Excella
Parsonsfield, , Maine
Glen,
Have you tried applying heat on the A-frame channel or box section to soften the insulation on the cables. Plastic and rubber insulation gets very stiff over time. Maybe a heat gun, hair dryer or spot lamp/heat lamp would help warm it up. A last resort could be to run the new cables/wire outside the frame and secure them with insulated cable clamps and stainless screws or run the new in aluminum conduit securely clamped. Charlie
CharlieE is offline   Reply With Quote
Old 07-06-2007, 07:27 PM   #6
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Here is what I did, I was really easy and I feel you can do it to - I did this on my 66 Caravel. First off - the old umbilical is really stiff with age. The outer sleave and inner insulation become stiff and brittle with age. Get a new umbilical with molded connector already installed from your RV supply place. Costs about $25 and will come extra long. Do not cut it untill installed - you will need the length.
I cut the connector off my old wire and pulled 2 (YES 2) small diameter nylon pull cords taped securely to the old cord. I then pulled the old wire out through the access panel under the front of the trailer. Then I used the pull cords to pull the new umbilical and brake wires through (I used one nylon line for both and saved the secound as a backup). The newer umbilical is very pliable and snaked in with no problem - I fed some on one end as I pulled. Went real easy.
You can also tape the nylon cord to the end under the trailer and pull from the front to get the old wire out.
I used a terminal strip and crimp on connectors to make my connections - the new umbilical colors will most likely not match the old wiring color scheme - CHECK FIRST. I connected all the existing wires on one side of the strip and then jumped one at a a time from the new cable until I made the right connections.
Mike
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 07-09-2007, 06:47 PM   #7
beginner5
winnipeg , manitoba
Thanks for the tips. I tried pretty much all that was suggested and got nowhere- I finally decided to coat as much of the wire as I could while electrical wire pulling grease ( available at electric supply stores or home depots etc). I then tied a strong rope to the front end of the cable where it comes out of the a frame and the other end to my truck and then slowly gave it gas. after 30 seconds of slow controlled pulling, it finally gave way and came out. I had attached a cord to the end so I will now be able to pull the new wire through. I am now cleaning out the channel in the a frame and widening the hole where the wire enters the connection point in the pan belly and will then proceed to pull the new wire through using the cord now running thru the channel
Old 07-09-2007, 09:02 PM   #8
1953 Flying
1953 Flying Cloud
1953 Flying's Avatar
Profile:  1953 21' Flying Cloud
Sacramento , California
Images: 8
[quote=beginner5]I then tied a strong rope to the front end of the cable where it comes out of the a frame and the other end to my truck and then slowly gave it gas. after 30 seconds of slow controlled pulling, it finally gave way and came out.
Now thats thinking out of the box way to go
1953 Flying is offline   Reply With Quote
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
Stand up power cord Happycampers Electrical - Systems, Generators, Batteries & Solar 0 04-18-2004 07:03 AM
Phone cord Joan D'Andrea Cabinets, Counter Tops & Furnishings 0 11-02-2002 10:38 AM
Automatic electric cord reel cameomike Batteries, Univolts, Converters & Inverters 5 09-02-2002 12:04 AM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 19 06-23-2002 09:07 AM
