Old 07-05-2010, 11:00 AM   #1
1998 25' Safari
Carthage , North Carolina
Inline fuse size off 12v bus
I have a '98 Safari 25' with a blown fuse. The fuse comes straight off the battery bus but I can not find it anywhere in my wiring diagrams.
There was a 1 amp fuse in it and that size just seems too small, especially with the size of wire that is used.
Name:	P7051622 (Large).JPG
Questions:
1. What is this circuit for?
2. What size fuse is supposed to be in there.
I attached a picture to make this easy.
Thank You
NCrider is offline   Reply With Quote
Old 07-05-2010, 12:43 PM   #2
1998 25' Safari
Nevermind, I answered my own question.
It is 1 amp, it goes to the LP Leak Detector....not a good fuse to be blown.
Old 07-05-2010, 12:47 PM   #3
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I can't tell you what it was for. If you start walking around the TT and turn things on one at a time. Sooner or later you'll find something that doesn't work. Replace the holder with another 1 amp fuse & see it it works now. That will tell you what it does. When you know what it is, read the instruction for that particular item. That should tell you the proper size of fuse.
If you find a light that doesn't work, keep going till you find out how many lights areout. Check them again with the fuse replaced. This will tell you how many light bulbs are on the circiut. The total amount of watts used will be the indicator of the fuse size.
My guess of the inline fuse would be something added on, not stock. Like a radio, antennea signal booster, audio amp......
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 07-05-2010, 12:49 PM   #4
3 Dog Nite's Avatar
Nice detective work. You posted the reply while I was typing in my 2 cents.
Ricky
12v
Inline fuse holder needs fixin' silversnail Jacks, Stabilizers, Lifting and Leveling 2 05-25-2010 05:37 AM
Need 12v fuse pjude Batteries, Univolts, Converters & Inverters 1 01-21-2010 04:38 PM
Correct size fuse for 12V circuits FLYNCLD Batteries, Univolts, Converters & Inverters 7 04-23-2009 05:39 PM
Fuse/12V Distribution Panel Mike S Batteries, Univolts, Converters & Inverters 5 11-13-2008 10:05 AM
12 volt inline fuse stops power??? tinbender Vintage Kin 6 07-09-2008 04:37 AM
