Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-03-2019, 01:39 PM   #1
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
Inergy Kodiak Solar Generator
Just wondering if any members are using a solar generator
like Inergy’s Kodiak to provide additional power as opposed
to a more traditional onboard solar panel system?
Thanks in advance.
Dave
davidrrand is offline   Reply With Quote
Old 03-03-2019, 01:47 PM   #2
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
I think that naming it a 'generator' is a bit misleading. Isn't it just a battery and inverter? It needs charging some way. Your Airstream already has an inverter.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 03-03-2019, 01:57 PM   #3
2019 22' Sport
I don’t own one yet but am seriously considering it. What’s not to like, you get a lithium battery and an invertor for a great price. It has an Rv plug in as well. Not all airstreams have invertors, mine doesn’t. I like the idea of a stand alone system that I don’t have to wire or modify my airstream, it’s plug and play. Also in the event of a grid down power loss scenario you have the ability to have power for your home as well.
If money was no object I’d already own one.
https://youtu.be/qPlsvVHR0lM
Kanusport is offline   Reply With Quote
Old 03-03-2019, 01:58 PM   #4
Sag Harbor , New York
FYI there are a number of threads where that unit has been mentioned:
https://www.google.com/search?q=iner...=airforums.com
For instance: http://www.airforums.com/forums/f37/kodiak-solar-generators-176395.html
The Goal Zero units have been discussed also as one other alternative:
https://www.google.com/search?q=Goal...=airforums.com
Peter
FYI/FWIW
Old 03-03-2019, 02:25 PM   #5
Car Generator
Maybe something like the Car Generator would be a better choice as an auxiliary power system as it would supply 1000 wats of power much longer (50-80 hours) than the lithium battery, and at a much lower price.
Ray B.
Old 03-03-2019, 03:24 PM   #6
Cloudland2
davidrrand's Avatar
Trenton , Georgia
Thanks guys! Sounds intriguing because of it’s small size and weight
and fairly powerful lithium battery. As far as it being misnamed, a
generator creates electricity but must be powered by an energy source.
I have two Honda 2000’s that require gas for the gas engine. Some have propane versions.
This “Solar Gen” requires solar panels (part of a kit system) but can also be charged from
your TV as you travel with optional cord or from AC plug in.
One dealer is offering the unit with three 100 watt panels, lights and AC charger for about $1900. Also features 1500 watt inverter with surge to 3000! My stock ‘16 FC can’t do that. Plus you can hook it up at home for power outages.
Only drawback is they are currently backlogged.
kodiak solar generators capt_ron777 Electrical - Systems, Generators, Batteries & Solar 4 09-09-2018 09:46 AM
Kodiak Disks undersized? 3Ms75Argosy Brakes & Brake Controllers 75 11-05-2009 12:38 PM
Debugging Actibrake with Kodiak discs and Prodigy controller ljmiii Brakes & Brake Controllers 10 03-04-2007 11:01 AM
Setup of Actibrake with Kodiak disks on Bambi mswartz Brakes & Brake Controllers 18 02-13-2007 10:31 AM
Kodiak Hydraulic disc brakes thenewkid64 Brakes & Brake Controllers 1 07-06-2004 10:48 PM
