Old 04-30-2016, 10:33 AM   #1
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
In-Sure connectors?
Has anyone used these? Or is crimp and heat shrink better?Click image for larger version
Name:	ImageUploadedByAirstream Forums1462034013.883797.jpg
Matt
rugjenkins is offline   Reply With Quote
Old 04-30-2016, 10:54 AM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Splice Connectors
have used that series in the house for 110 VAC wiring, but prefer twisting the wire + 3M wire nuts + tape.
in the trailer we like these for low voltage - http://www.homedepot.com/p/Tyco-Elec...4-10/202204352
they come in multiple sizes from 10 to 22 gauge.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 04-30-2016, 03:18 PM   #3
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I just used them on a new fixture installation in my house because it came pre installed on the fixture. It made making connections super easy and the wire is removable if needed. I then went out and bought some for the trailer and my home. They take up less space than wire nuts and they are available for 2, 3, 4, etc. wire connections.
Hiho Silver is offline   Reply With Quote
Old 04-30-2016, 04:07 PM   #4
2007 22' International CCD
In-Sure connectors?
Not worth a darn in a vibrating trailer. The spring will work its way through the wire and lose contact.
Wire nuts are bad enough. I use only crimp connections made with a ratcheting tool. They stay put.
I had a few home fixtures with these in them. Tossed and used real wire nuts. I also never back wire outlets and switches. Wire goes under the screws...
Yep. Old fashioned but proven to work better.
KE4GNK/AE
Old 06-11-2017, 11:35 AM   #5
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
Originally Posted by rmkrum View Post
Not worth a darn in a vibrating trailer. The spring will work its way through the wire and lose contact. Wire nuts are bad enough. I use only crimp connections made with a ratcheting tool. They stay put.
What UL-listed crimp connectors do you use in your AC wiring for connecting 3 or 4 , 12 AWG conductors?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 06-13-2017, 01:20 AM   #6
In-Sure connectors?
In not sure of the brand, think it's Thomas and Betts, but I use an uninsulated crimp sleeve, a ratcheting crimper, and marine grade shrink tubing with the glue in it. Got at the local big box store. Parts are designed for splicing UF (underground feeder) cable for direct burial.
I do everything I can to avoid 115 volt inline splices. They are prone to failure. Better to splice inside a junction box if possible.
KE4GNK/AE
Fleixble gas connectors on Suburban furance? Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-20-2009 07:36 AM
Pex connectors and bad temper crispyboy Fresh Water Systems 36 05-06-2008 08:31 PM
P30 fuse blocks and connectors bkahler Mechanics Corner - Engines, Transmission & More... 6 06-08-2007 07:10 AM
240 volt connectors??? gparker Electrical - Systems, Generators, Batteries & Solar 4 07-31-2006 04:57 PM
12vDC wall connectors walter1 Electrical - Systems, Generators, Batteries & Solar 10 09-19-2004 12:53 PM
