Old 11-29-2012, 03:58 PM   #1
Portland , Oregon
In Need of: 1959 Overlander Electrical Schematic
hello!
i am a newbie to the airstream world and recently purchased a 1959 overlander. i am looking forward to renovating it. i'm desiring to re-wire the trailer and am wondering if anyone has an original wiring diagram for the trailer?
i have some friends who are skilled electricians that will help me do the job, but i'd like to provide them with what is currently in the trailer.
any resources, direction or advice would be greatly appreciated. thanks in advance for your help! i love seeing the community care on the forum. hopefully one day i'll be able to help someone on here with their questions!
rachel
OLandy59RKS is offline   Reply With Quote
Old 11-29-2012, 05:00 PM   #2
nmbosa's Avatar
Nowhere , Washington
I don't have a schematic, but can tell you the wiring is impossible to re-do without gutting the trailer and taking the interior skins down. All the wiring - 12v and 110v is run behind the interior skins through the ribs (with grommets protecting the wires). When I took mine apart, I found that the junctions were all butterfly'd together without junction boxes. The work was well-done and none of the connections were loose, but it makes it impossible to simply pull a run of wire from box to box.
Unless you have serious problems with the wiring, you might just want to repair and upgrade only those areas you can access without taking the whole trailer apart. You should be able to fix any connections at the outlets, lights, your panel and the 12v fuse box. Any wiring that is not run behind the skins is likely an addition by a previous owner that you should examine carefully for problems. The stuff Airstream did held up very well in my trailer.
Here are a few photos of what it looks like behind the skins. Notice the loop of unused 110v wire between the two windows? That was in the kitchen. Looks like Airstream left that in case someone wanted an extra outlet just above the stove in my trailer. The sharpie marks are mine, but there were wax pen marks from the original electricians that showed the intended paths of all the wires.
Norm
ID:	173565   Click image for larger version
ID:	173567   Click image for larger version
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 11-29-2012, 06:21 PM   #3
Central , Mississippi
I HAD the original schematic somewhere but it is actually useless. The 12 volt side was all in one circuit with 1 thermal breaker.. The 120V side was a bit better but anyone with Home wiring experience can do better.
A couple of notes. Make sure and run the wires through grommets when they pass thru a hole in the aluminum. Don't tie the neutral and ground lines together. The neutral line needs to be completely isolated from the shell.
On Edit...WELCOME TO THE FORUMS!!!!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
1959, 1959 overlander
