Old 10-28-2006, 05:38 PM   #1
jemison , Alabama
I need advice
Ok. My "new" 1974 airstream needs a new distribution panel. I baught a progressive dynamics 9260 converter. Should I build a new panel (which I'm not sure how to do exactly) or should I buy one?? If I buy one, where and what do I need? I seem to find 30 or 50 amp panels for sale but my converter is 60 amps. Do I need a 60 amp distribution panel? Also, I am parked permanently with sewer so I don't have a black tank or grey tank and I will very seldom use the main tank so I decided to ditch the control panel. Will this cause me problems? I took out the furnace also. I put electrical tape over the wires that went to it and was just going to shove the wires in to the wall as opposed to acualy removing the wires frome the whole wiring system. Does having open wires effect the rest of the electrical system. I know this is alot of questions but I really need help here. Thanks ahead of time!
rama777 is offline   Reply With Quote
Old 10-28-2006, 05:45 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
If you can return it, exchange it for a power center, it will do it all!
'77 Sovereign Intl 31' CB
Old 10-28-2006, 05:46 PM   #3
Images: 59
Rama,
You are looking at two different things. The 60 amp converter is for the 12VDC system, so it put out 60 amps of direct current at 13.6 volts.
The 30 and 50 amp panels are for 120VAC current, the same as in your house.
If this causes you to slap your head and say "doh", then we can continue to the next question. On the other hand, if this sounds like Latin to you, I would advise you to consult a RV tech/electrician.
Old 10-28-2006, 05:52 PM   #4
jemison , Alabama
Ok, maybe it isn't a distribution panel I need, but rather a fuse panel. Sound better?
Old 10-28-2006, 05:56 PM   #5
jemison , Alabama
Unfortunately I can't return it.
Old 10-28-2006, 05:59 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Ok
Ok, then pickup a fuse panel about $35.
Bestconverter has 'um
Old 10-28-2006, 06:05 PM   #7
jemison , Alabama
http://www.bestconverter.com/9-Posit...k_p_57-61.html
Like this?
Old 10-28-2006, 06:12 PM   #8
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Yes, call Randy, he can give you some pointers.
Old 10-28-2006, 06:18 PM   #9
jemison , Alabama
Thanks!
Old 10-28-2006, 06:20 PM   #10
jemison , Alabama
Wait! Who's Randy? Sorry.
Old 10-28-2006, 06:21 PM   #11
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
He owns best converter
Old 10-28-2006, 06:24 PM   #12
jemison , Alabama
That's what I thought. Thanks again.
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
Advice for long term trailering Cheryl Full-Timing 49 07-29-2004 01:58 PM
Parking it up north: advice? tonigm Our Community 1 10-17-2002 08:06 AM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
