Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-07-2002, 08:35 PM   #1
FrankR
Profile:
I have made many electrical changes
I really like Airstream trailers, but the electrical is poorly designed and executed.The 12 volt system is redesigned and I have removed all fuses, changed to manual reset circuit breakers, removed fuses for all exterior lites and installed a 2 battery selector switch. The converter has been recessed into the floor into an aluminium box for noise and to shed heat from unit. A photo shows some changes.. Frank
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 03-07-2002, 08:52 PM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Frank, I noticed that the fuse (20amp) running my main interior lights (12 bulbs) tends to get extremely hot, when turned on for a while.
I cleaned the contacts and replaced the fuse.
Is there a better solution?
PeterH-79MH is offline   Reply With Quote
Old 03-07-2002, 09:43 PM   #3
FrankR
Profile:
Interior lites current
I do not know your particular RV. Just a few conditions can cause a temperature rise at the fuses. The choises are poor or dirty fuses, poor or dirty fuse holders, too many lites of too hi wattage or amps and finally poor mechanical connections at the fuse. The fuse holders become overheated or distorted with bad removal and replacement. The fuse holder ends need to be crushed to make a VERY firm connection when fuse is installed. Suggestion........while fuse is removed, install an amp meter with at least a 50 AMP deflection and observe how many amps are being used. Any smaller meter will make fire or toast. Remove a battery cable so as to make no electrical power to coach. Have helper connect cable after meter connected. Tell how it works..
Frank
electrical kent osborn 1966 - 1968 Safari 13 05-08-2005 08:09 AM
Marker light electrical sealer? TomW Electrical - Systems, Generators, Batteries & Solar 2 01-26-2004 07:22 AM
Wanted: Electrical Genius jthew1 Our Community 15 12-14-2003 08:35 AM
AC electrical problem lbf78SvgnInt31 Electrical - Systems, Generators, Batteries & Solar 2 07-26-2003 06:44 PM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
