Old 02-27-2006, 02:03 PM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Hypothetical ??? Jump start TV from AS...
Greetings.
Let's say you are out camping someplace in the middle of nowhere, you go to start your tow vehicle and find you have a dead battery.
If you had long enough jumper cables, or your vehicle happened to be positioned right could you:
A) Get a quick jump from the coach batteries on the AS or
2) Same as above, but if not, could you have a generator running power into the coach, and THEN jump the tow vehicle from the AS battery(s)?
Would either or both of these situations pose significant harm to either the AS or TV?
I vaguely remember this question came up somewhere else, so sorry if this is a repeat.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 02-27-2006, 02:09 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
You could use jumper cables to the coach battery, should not cause any problems. Not sure what running a generator to power the coach would do for you. You could always disconnect the battery from the coach, to be on the safe side and just jump from a bare battery.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-27-2006, 02:44 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
or depending on how your vehicle is wired, just plug in the umbilical, and the trailer's battery will just "mate" with your tv's electrical system.
since the charge line on my truck is not switched, (i.e. "12v/40amps all the time), this would work, and if I leave it plugged into the trailer overnight, with the trailer connected to shore power, the univolt will charge my truck's battery.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 02-27-2006, 04:03 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have done exactly that with my old SOB and tow vehicle many years ago. It took about three hours to charge the battery enough to start the car, but it worked.
Old 02-27-2006, 05:54 PM   #5
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Just today I jum started my motorhome buy jumping from the coach batteries to the chassis battery, twice.
I don't see any difference in the TV to coach case except for the length of cables needed.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 02-27-2006, 10:20 PM   #6
_
hi crazylev and others
well if you have the genset available.......honda makes a 15$ set of cables that connect to the generator and will charge/jump the t.v. battery.
it would be easier to carry the genset up to the t.v. battery, than any of the trailer/battery options...
cheers
2air'
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
Aaaargh!!! Motorhome won't start!!!! AGAIN!!! eraffety General Motorhome Topics 14 01-19-2003 06:40 PM
Buying used Airstream dinoburb Buyer Guidelines 12 12-19-2002 02:31 PM
