Old 07-29-2016, 10:26 AM   #1
2006 19' Safari SE
Hayes , Virginia
HVAC Dometic
Turned AC on for first time in several months and it doing following:
Set up normal settings, 72 deg and below. Unit comes on and runs about one minute, brings vent temp down to 78 deg's, cuts off for about 2 minutes and repeats cycle. Took hood off and all looks normal--clean etc.
Low gas? (don't know what to call it). Any ideas with such limited info? As always, any help will be greatly appreciated. Thank you in advance.
mocus is offline   Reply With Quote
Old 07-29-2016, 11:07 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
What was the inside temperature of the trailer when you turned it on.
With very high inside temperature I have had the same issue. If the AC sees very high head pressure, heavy load noted above, it may shut off on high head pressure. If this happens again try spraying water on the condenser when the AC comes on. That will lower the head pressure. Depending on how hot the trailer is you may have to do this for several minutes.
This works for older AC that had better controls but may also help here.
2004 Excursion 4x4
Old 07-29-2016, 11:58 AM   #3
2006 19' Safari SE
Hayes , Virginia
Trailer sets under a carport, covered by tree (all shade). Temp probably 80deg. She doesn't get up above that at home. I felt copper tubing on top while unit running and all touchable (none cold). Unit runs about minute, off about minute, and repeats cycle. I believe(?) at least one line should be cold but not sure
Will give your suggestion. Thank you.
Old 07-29-2016, 12:24 PM   #4
HowieE's Avatar
Images: 12
Well if it is not abnormal high load causing the problem it may be low gas and the compressor is heating up from lack of cooling from the returning refrigerant.
Try setting the thermostat as low as it will go and see if the AC will remain on longer. If it remains on for more than 5 min. take the temperatures at the return and supply grills. You should see about 18 degrees difference. If it will run longer and supply cool air the problem may be the thermostat.
2004 Excursion 4x4
Old 07-29-2016, 02:09 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Could be any number of things but the most typical cause is some obstruction that keeps air from reaching the outside coils. Leaves, dirt, fan not actually turning or loose on the shaft, etc.
Old 07-29-2016, 02:33 PM   #6
2006 19' Safari SE
Hayes , Virginia
Thanks both of ya, unit working now. There was nothing blocking in the roof unit when I removed cap. However, that is when unit started working, and I cleaned things off a bit. Reading other post today re HVAC's answered some questions.
Thanks again.........
Old 07-29-2016, 02:47 PM   #7
HowieE's Avatar
Images: 12
That is very odd. Removing the cap completely eliminates air flow over the condenser. Look at the gasket configuration under the cap and you will see what I mean.
Has that unit run in very dusty locations? If so the condenser coils may be clogged on the face side and removing the cap allowed the back side of the coils to give off heat simply by convection.
2004 Excursion 4x4
Old 07-30-2016, 08:19 AM   #8
2006 19' Safari SE
Hayes , Virginia
I see what you mean...never new what the foam channeling was! Have completely cleaned...wasn't dirty at all nor anything clogged. Unit working great now (fingers crossed). I'll give the first 2 gentlemen credit for getting me started. Only thing, is this fix temporary? Would hated to for this to have happened while on a trip. Unit hasn't been anywhere there was dust..yet.
Attempting to install loveseat recliner today. That stock leather couch is worthless. Will keep couch in case ever resale. You guys are great!
Old 07-30-2016, 08:23 AM   #9
2006 19' Safari SE
Hayes , Virginia
I see what you mean...never knew what the foam channeling was! Have completely cleaned...wasn't dirty at all nor anything clogged. Unit working great now (fingers crossed). I'll give the first 2 gentlemen credit for getting me started. Only thing, is this fix temporary? Would hated to for this to have happened while on a trip. Unit hasn't been anywhere there was dust..yet.
Attempting to install loveseat recliner today. That stock leather couch is worthless. Will keep couch in case ever resale. You guys are great![/QUOTE]
Old 07-30-2016, 08:26 AM   #10
2006 19' Safari SE
Hayes , Virginia
Whooooops
Old 07-31-2016, 02:35 PM   #11
2006 19' Safari SE
Hayes , Virginia
HVAC unit running great for 15 minutes then throws the 20amp breaker in house power panel. Still have the hood off of unit, but still under carport. Could by not having hood covering in place cause unit to run too hot in a short time and throw breaker??? Nothing else turned on.
HVAC thermostat opinions please! AtomicNo13 Electrical - Systems, Generators, Batteries & Solar 8 07-10-2012 05:08 PM
HVAC Experts-Please Help tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-03-2012 08:50 PM
Help an HVAC noobie out... can I combine the furnace and A/C t-stat? Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2012 03:13 PM
Generator--HVAC Question Tideair Generators & Solar Power 10 03-14-2012 10:24 PM
Airstream - Free Standing HVAC anglev Winter Living 8 12-04-2011 08:20 AM
