Old 08-31-2017, 04:42 PM   #1
2017 25' Flying Cloud
Baton Rouge , Louisiana
Husky 5000 watt and Flying Cloud 25?
Can I run my FC 25 with a Husky 5000-watt generator? The FC's plug does not fit the main receptacle for the generator, and even if I get an adapter I'm not sure about plugging it into a 240V, 20amp socket. Here are the specs for the generator, attached as a one-page PDF. I would appreciate any advice.
chustmyre is offline   Reply With Quote
Old 08-31-2017, 06:20 PM   #2
Images: 59
Is your FC 25 wired for 30 amp service, or 50 amp service.
Usually 30 amp will have one air conditioner, and 50 amp service would have two air conditioners on the roof.
Old 08-31-2017, 07:12 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Hold On - Trouble Ahead
Heck NO! Your trailer is 120v, not 240v. You can only use the four smaller sockets for electrical. You'll need a dogbone configured like this:
https://www.amazon.com/Camco-55165-P.../dp/B000BUU5YA
Or, an adaptor like this:
http://www.homedepot.com/p/GE-30-Amp...3020/202307108
You shouldn't use your Air Conditioner when attached via the 20 amp plug unless you have also installed a Micro-Air 364 to reduce/manage the AC startup amperage load.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-31-2017, 08:16 PM   #4
It's 30 amp.
Old 08-31-2017, 08:49 PM   #5
Images: 59
If it's 30 amp you will only be able connect half of your generator to the coach, which will limit you to 20 amps, or half of your generator capacity.
Plug your 30a trailer cord into one of the 20a outlets on the generator, or one of the 4 receptacles on the 30a power cord that came with the generator.
If you want to use the other 2500 watts of your generator capacity you will need to run a cord from the generator directly to the appliance you want to use. For example, you could run an electric skillet on the picnic bench.
Old 09-01-2017, 06:40 PM   #6
2016 25' Flying Cloud
2003 22' International CCD
2004 28' Safari
Sahuarita , Arizona
warning - 240 volts
Check the comments above on this. Your trailer is NOT 240 volt.
AzAirstream is offline   Reply With Quote
5000 BTU/hr AC and 1,000 Watt Genny TouringDan Furnaces, Heaters, Fireplaces & Air Conditioning 37 10-09-2019 11:24 PM
200 Watt Solar Install on 2016 Flying Cloud 19' Snowy Generators & Solar Power 6 11-26-2017 05:44 PM
Suggestions on Upgrading stock coach batteries to 400 Watt from stock 160 Watt odonnell71 Sprinter and B-van Forum 5 05-07-2017 08:59 AM
Goodyear Inflator 5000 12 V and 120 AC not great Driftin Di Tires 0 03-22-2017 06:15 PM
Husky 5000 Watt Generator The Flintstones Generators & Solar Power 18 09-27-2008 11:44 PM
