Old 03-09-2014, 07:00 PM   #1
dave_oleary's Avatar
2013 25' FB International
Gig Harbor , Washington
Hubble Wirecon Tamper-Resistant SCD
Has anyone ever installed one of these electrical outlets? My 2013 International has these, and the one the TV is connected to only has one working outlet, the other is a dummy. I'm not sure why AS did this. I was trying to plug in a cable tv box to this tv but the only working outlet in the area had the tv plugged into it. I would like to swap this out with the same type of outlet, only one that has 2 outlets in it. I saw a PDF show a tool used to compress this outlet and I'm not sure if that's required. I will include a picture to help visualize this.
dave_oleary is offline   Reply With Quote
Old 03-09-2014, 07:11 PM   #2
This is the tool I saw for installing, but I'm not sure if it's required.
Name:	ImageUploadedByAirstream Forums1394413887.696543.jpg
Old 03-10-2014, 08:21 AM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Do you have an inverter? If so, could it be wired to the other outlet?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-10-2014, 08:50 AM   #4
1974 Argosy 20
Kooskia , Idaho
My 2014 FC 20' has one of those strange one plugin only outlets too, but it is on the inverter circuit. I just put a simple cube tap on it when I want more places to plug in. No need to make a big project.....grin.
Old 03-10-2014, 08:57 AM   #5
dznf0g's Avatar
Oswego , Illinois
The tool isn't required...but it is a bit tricky to insert the wire into its compression slots without it. Do you have a link to the website from whom you are shopping?
-Rich-
SilverGate's Safari is Home at Last! SilverGate 2007 Safari SE 564 10-09-2017 05:58 AM
